I have stock 275/55/20's and the 2" rc spacer and it rides just like it did before the spacer. Perfect amount of lift for a level IMO.
theres a guy in my area with the 2.5 rc kit and hes running 285/65/20 with the stock 20" wheels. looks really good. does anyone else have this setup? any rubbing issues?
I will be running 20x10 with 305s I'll let you know. Quite a few other people have ran the same setup with barely rub on liner.
If I have the 2 inch leveling kit on my 2wd.......
Can I stack leveling kits on it and be ok scenes it's 2wd????
I have the 2 inch on the bottom which makes it level now but.... I wanna add the 3 inch on top of the coil and the 2 inch block in the rear and clear a wider rim this should only make the truck sit 1 inch higher in the front
Edited by Devinc
i installed a 2.5" leveling kit and now interested in upgrading the shocks, I spoke with a Bilstein rep and he told me that he doesn't recommend installing Bilstein 5100 with a leveling kit. He said they do not have any shock for my application. anyone heard of this?
Finally got around to getting the RC2.5 installed on my truck.
Waiting on the new wheels to be finished getting drilled and then will take another picture.
Before: 595327548fdfd7ddf4dbf9889b187ea4.jpg
After:
Same setup I've had on mine for 28k miles (since new). Couldn't stand the low riding no ground clearance truck look. Removed the front airdam (valence) and the rear splash guards. Total change in look and height appearance. What wheels you going for?
Got my RC 2.5"/1" leveling kit & BFG AT KO2 275/65/20s installed today. Love it
Man that looks really good!
I have RBP Glock (20x10) (305/55/20 Toyo AT2s on the way. Just waiting for them to drill them and send them out.
Edited by Wazbe
So here is the beast.... 2016 Stamped control arms 2wd 295/55r20 2.25 ready lift, tire hit and rub on sway bar..... going to 285/55r20
Edited by Catman5906
i was just about to ask guys about getting some shocks I have the RC 2.5 lift I was under the impression the 4600s where the ones to go? I'm trying to smooth out the ride when going over bumps and railroad tracks since there is one right by my house
I am running 305/55R20 on stock rims and there is incredibly slight rubbing on the felt and on the control arm at full lock with a 2" level. Not enough for me to actually do anything about at this point.
That would mean there would be a lot more rubbing with the 12.5" width as the ones I have are more like 12"
Can u post some pics? I want the same setup but I have +18 wheels. Do u have the g2 xl? How's mileage?
Mileage has suffered a bit. I would estimate ~2MPG loss.
Edited by Havvkeye
What is the offset on your wheels?
    jack-arrrdor
    jack-arrrdor
  • Who's Online   2 Members, 0 Anonymous, 1,433 Guests (See full list)
