Question for all you 2.5 RC enthusiasts. What are your thoughts on doing the the front 2.5 setup and putting the universal 5 inch blocks in the rear instead on the supplied 2 inch blocks?
Currently I have a 3" rake going on and figure it would only take .5" out of my rake but give me 4" in the back and 2.5" in the front.
Also curious going up to a 5" block with that kit and the u bolts wont work so what length u bolts I would have to go with?
Thoughts?
5 inch block would look ridiculous with a 2.5 level up front. I would go 3 inch block max and it still would be a lot of rake. The 2 inch block would look best imo
Does anyone know if the rear end spacers are safe if you're towing at near capacity?
I got rough country Leveling kits installed at my local shop but they don't have the alignment specs for the 2016 Silverado. They are just going to use the 2015.is it the same? How did you guys get ur 2016 aligned? Thanks
I did 2015 specs as the truck hasnt changed
Thanks, that's what the shop ended up using.
Edited by jlilnc14
Ok been following this section for a while and would like to know about having the magnetic ride shock sensors recalabrated.
I have a 2015 Denali 1500 4x4. The Dealer put on a Suspension Maxx 2 1/2" level up front and a 2"Block in the back about 6 mo. ago.
My truck looks great but rides like a lumber wagon (Very Stiff) , so I ask them about recalabrating the sensors. As I have read about it here.
They said never heard of it and it was not needed? So my question is who can check this for correct position besides a dealer that is clueless?
My understanding is this is computer related for a software update correct? I also need to note that I am also running a 10 ply tire so I know there will be some stiffness but didn't expect it to be that bad.
Any help?
Any help?
What pressure are your tires? My tires were installed inflated to the max. Rode horrible.
Anyone have any experience with the Eibach leveling shocks? I have been in the market for new front suspension and was planning to wait for the 6112 Bilsteins to come out, but stumbled upon these. Most of the reviews are people who have them on Toyota Tacomas.
http://eibach.com/am...ro-truck-shocks
According to Eibach:
PRO-TRUCK Sport Leveling (RHA)
Also, if I already have a front leveling kit can I just throw these on, or do I have to remove the level kit?
Thanks in advance.
45 psi is what they are currently. I believe 80 is max pressure and ya that is wayyy to much. What did you drop yours to? Do you have any experience with a level and magnetic ride shocks?
Looking to level my 2014 CC Sierra all terrain. Definitely gonna go with a bottom strut spacer and was leaning towards a 2" from motofab. I saw that motofab actually offers a 2.5" bottom strut spacer kit. I haven't been able to find any information from anyone who has one, as most with a 2.5 have a combination top/bottom. This makes me concerned that maybe 2.5" is too much to put only on the bottom of the strut. Can anyone offer any insight on this??
I have a 2.5" level kit and I just put on 20x10 -19 offset Fuel Hostile and Atturo Trail Blade XT 275/55R20 XL (31.9x10.8x20) not the largest tire, but everything fits without rubbing. No trimming needed. If I went with 33's it definitely would be rubbed, but in the future I probably will go with 33's to fill the gap between wheel and fender.
Edited by BoomBoom19
is there any way to get another little bit of lift on truck. i currently have a 2.5 inch level kit on truck all is good with it . but would like to maybe go 1/2 to 1 inch more anyway simple way to do this . im always an inch short lol
There is but it'll end up looking like post #2974 on this page http://www.gm-trucks.com/forums/topic/161228-post-your-2014-wheeltire-set-up/page-199
And your suspension parts will be all sorts of messed up and wear out prematurely.
If you wanted to do it the right way, you're going to have to either:
ditch the leveling kit and get a 3" or larger lift kit with drop spindles, etc.
OR
at bare minimum get new UCAs for a 3-inch level.
What about a body lift? I have no experience with them, but they look like reasonable solution to a little more height.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
