What is everyone's thought on the MotoFab lifts? Looking at purchasing the 1.5" level kit for my 2014 1500 Denali. Thoughts are welcomed.
I went with the Motofab 2.5” and I love it. I was able to get 285/70/17 MXT’s on there with zero rubbing. Rides like stock in my opinion.
Why is it that rough country is only spot that asks for control arm type? MotoFab doesn’t ask at all, and nothing gets installed as a preload spacer - it’s all right on top of strut like older models.
Edited by Criscone
I went with the Motofab 2.5” and I love it. I was able to get 285/70/17 MXT’s on there with zero rubbing. Rides like stock in my opinion. c3c0303ccef6e27ba37384e3146221c6.jpg
Great looking ride. I just ordered Falken Wildpeak AT3W 275/55R20. I'm torn on either the 1.5" or 2" level.
Thanks man!! I love the way it sits right now, but I have to do something because I left no rake. When I hook up the boat she squats and looks like shit. I’ll probably do air shocks in the back so I can keep the look and then give it some air when I tow. I don’t tow a whole lot right now other than my small boat, so it will be a project for the winter While the boat is stored. We are looking at a camper too so that will definitely make the bags a priority.
Rough country uses a spacer between the lower control arm and the strut assembly. The different control arms might have different hole spacing or thickness (would need different length bolts).
Edited by KyleGT
I get that part, and yes it’s the thickness. I’m talking about the reason some companies use just a top 2.5” spacer on TOP of strut while others use a 2” lower and .5 upper. Also why is it that my 15’ has the .5 spacer on TOP of strut but my 16 would have to have it on top of the coil spring as a preload and not on top anymore.?
Searched for two days now...... Anyway i have a 2016 LTZ midnight editon. i am looking at leveling, my question is for Nitto trail grapplers, can i run a 285/65r18 or the 275/70r18 on the stock 18's without rubbing? there seems to be some that are making things work without cutting and others that are saying it cant be done. I'm at a loss on what to do.... TIA
Either should fit fine on a stock trucks with stock rims. If you level 2" or more, both should clear with no problem. I say "should" because those are popular sizes and many people on this forum are running them without issue. At worst, the 285s might hit your UCA, but it won't be bad.
For anyone who had a level kit and then upgraded to Bilsteins...
Did you keep your level and put the Bilsteins in at lowest setting? Or did you take the level out and put the Bilsteins in at highest setting?
I've heard the Bilsteins at highest setting is a "rougher" ride. And I don't want to lose the quarter inch as I have the MotoFab 2" level kit.
Thanks in advance!
Sent from my Pixel XL using Tapatalk
Thanks in advance!
I wouldn't call the bils at the highest setting rough but theres no bounce really compared to the factory shocks i replaced. bumps are a quick jolt. It can be a little hash at times but ill take that over the bouncing up and down any day.
5100s at highest setting on 275/60r20 KO2's
Looks sharp!
What are you averaging MPG?
I'm running BFG KO2s in 275/70R18 and did on stock wheels for a couple years with no issues whatsoever.
If you level you shouldn't have anything to worry about.
I also ran 285/65/18 BFG KOs on stock wheels with and without a level and never had any rubbing.
I would think you would be perfectly fine with those.
They shouldn't be wide enough to rub anything. At most I would think you might have to trim the felt fender liner just ever so slightly as the 275/70s are decently tall.
Looks sharp!
17.5 +/- 1 depending how I’m feeling or if I’m mashing the throttle in Houston lol.
Get about 14 with a 16 foot trailer depending the load.
I also have been researching this for weeks. Think I'm leaning towards a pro ryde 2.5" kit and leave out the .5 spacer on the top for a 2" front lift.
Then go with a added 1" in the rear also from pro ryde.
Then go BFG KO2's 285/65-18 on my stockers.
Wish they offered more 295/65/18 that were not so damn expensive.
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • Is it an optical illusion in the pic or is the truck really squatting that much horribly?
    • My initial introduction was here.  It's hard to believe that I last posted in February 2013, having just deployed to Kyrgyzstan.  Since then, I've retired from the military and the 2006 Sierra SLT Z71 that first brought me to these pages was lost.  I went forward to Afghanistan in March 2013 and did a lot of sitting behind a computer on brigade staff.  Within 18 months of getting back to the States, I was selected for Drill Sergeant duty, after which I moved back to Virginia (my home state and where I served from 2004-2008).  That '06 Sierra did a lot of driving between Louisiana, Georgia, and Virginia, and ended up with nearly 320k miles by 2022.  By then, the registration had been expired for a couple of years, but the pandemic had all but eliminated tickets for such transgressions.  Admittedly too, I usually drove my wife's SUV or son's car the 2-3 times a week I had to report to work.  Teleworking sure was fun while it lasted.   I started my retirement leave four years ago and stored the Sierra at my sister's house.  A big mess was made when her fiancé passed while she was taking care of business out-of-state in late-2024, and his son pretty much mismanaged everything to do with the estate.  Even so, I was assured that my truck was safe... until it wasn't.  I found out that my truck had been scrapped about four months after the son took over everything.  There's nothing I could do; I'm 1000 miles away and it was technically abandoned property since he'd even trespassed my sister from her own house (she had no claim to it as she wasn't married, and the fiancé was the sole owner).     Anyway, today I got my second Sierra.  This is a 2010 SLE 2WB CCSB with a little over 200k miles on it.  It's got the 5.3L I'm familiar with and should handle what I need it for.  Hauling stuff that won't fit in the Transit Connect (yep, I sold out, but that's the wife's vehicle) and towing a few times a year tops.  The price seemed decent, considering how much people sell their trucks for in the Deep South: $4500.  I've seen similar trucks listed for more than double that.  I got it from a coworker who left his tag on until we transfer the title next week (Louisiana requires a notary for transfers), so I've been driving it all day.  The rear speakers don't work, which is one of the things that brought me back to these forums earlier.  I can't say how active I'll be as a poster, but I'll be scouring the archives while I find out every little thing I can about the 2010s and particular nuances/problems with my truck.   It's definitely not a GMC, but I got another Willys Jeep a few months back as well, so I'm almost at the same place I was when I first joined gm-trucks.com.  My old 1960 DJ3A was sold back around 2010 or 2011; my current Jeep is a 1946 CJ2A.  So, I've got a slightly newer GMC and a much older Jeep.  I kind of wish I still had that F-250 I had way back when too.  The Dakota is long gone and was technically my brother's truck, though I had it registered and insured.  The F-250 had to go when my grandmother's house was foreclosed on due to mismanagement around 2012 or so.     Hopefully anyone that made it this far isn't too annoyed.  I tend to be long-winded, but I'll be doing more reading than posting in the coming months.
