I have the RC 2.5 leveling lift kit, for some strange reason on stock tires/ 20 rims it's rubbing on the sway bar just the driver side tire. I love the look but I will be taking it off and going back to stock due to warranty and don't want any issues when taking it in. 6k miles also noticed it pulls to the right when braking, not a hard pull but my cousins 2016 Chevy truck with about 300miles does not pull to the right or at all when braking. I don't believe it's the lift kit but still taking it off.
Get your alignment done
It was already done after the lift kit.
Are your control arms stamped steel and positive you used the correct kit for those arms? What size tires?
Stamped steel, yes I got the correct kit and factory 275/ 55-20
I don't see how you are rubbing your sway bar on factory wheels and tires makes no sense, something is incorrect
I agree with you, I don't know as well but tomorrow I'll be taking it all off and back to factory and another alignment.
That's weird. Keep us posted...
Sent from my Nexus 6 using Tapatalk
I would have it rechecked. It seems like there is an obvious problem.
I agree but the rear end blocks is off now and tomorrow I'll be taking out the leveling lift kit on the front suspension. Just eye balling it I can tell theirs Postive camber on the passenger side/ camber was adjusted on that side definitely and I agree I need the alignment rechecked.
But that doesn't explain why it pulls right somewhat when I brake AND why is the driver side factory wheel/ tire rubbing on the sway bar...
Photo%20Nov%2013%2C%203%2058%2005%20PM.j
Need some opinions. Do I shackle rear end or level front end? It's a 2wd so not exactly how I sure about leveling but interested in other peoples thoughts :)
On a 2WD I'd drop the rear to match the front, on a 4WD raise the front to match the rear. It's just a matter of personal preference, though.
Any suggest blocks for a 2" front level? I need at 2" increase for the rear
    RichardRS
    RichardRS
  • Who's Online   1 Member, 0 Anonymous, 826 Guests (See full list)
    • Well that book won't sell many copies. Taking ones right foot off the loud pedal never gets applause. Funny really, It isn't that people don't know what to do...they just don't want to do it. But they will complain about it. About bad craftsmanship, about the cost of fuel, about the cost of part and repairs and mainly they complain that the solution while still possible isn't one they are willing to do.    I observe this daily. 'Gas cost to much!", they wail, while they mat it passing at 80+ mpg and scoot down the road like gas cost a dime a gallon. Then complain about the few that will lift and save both fuel and iron like they are owed and own the road.    Good thing they haven't an ounce of influence on my equipment. The rest I just laugh at. Stupid is as stupid does, right Forest?
    • Today I filled up with 4.899 gallons of fuel at a cost of $4.899 a gallon. $24 bucks. 290 miles. 59.2 mpg. After my 4% COSTCO discount just under eight cents a mile.
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
