I have a 2 or 2.5" RC front level, and I am running stock rims with 285/65 ko2's...I love them... they don't stick out past the fender (so if you want that look need to figure something else out)...but I think they look plent y beefy and work well for me at least.
(Black truck in my sig for a visual)
Man, that's a pretty truck. Are you on the 20" wheels? I have 18s. I don't need tires yet, but I was leaning towards those.
What are you driveline angles like? Any ride issues?
Thank you! Stock 18". Personal preference but I like a little more rubber for the 4x4...plus they are cheaper for tires (and rims too if you decide to upgrade).
I don't know of the exact angle, but from this site and other resources, I gathered that a level kit doesn't put additional strain on your drive line... if you start getting 3"+ that is when you start changing the angle enough to at least consider what you are doing... plenty of people have a larger lift and can tell you their experiences...I just wanted to keep it pretty simple, just differnt enough that it isn't 'stock'...if I wouldn't have got the midnight edition I would have upgraded my rims... but I liked them enough to keep them and save me a couple grand...
Well a buddy and I installed my RC 2.5" lift yesterday however I was an idiot and forgot the u-bolts for putting on the 3" blocks, so currently only have the 2" installed. It'll be January at least before we get back together and do the blocks. Smdh
Now I just need to figure out what tires I want to put on my 20" stocks.
do you happen to know what upper control arms you have?
I will be interested to see what 4emeryj44 reports back with. I'm running 275/65 Nittos and at FULL LOCK, I can't get a finger between my inner sidewall and the UCA. The Swaybar probably has 3/4" or more before it touches the tire.
I don't think many people realize that inner sidewall rubs the UCAs as it probably doesn't cause much vibration or noise.
You're welcome. I agree on the size. IMO, the rim should only be big enough to make sure the sidewall isn't too big for on-road stability. Funny enough I parked next to a Midnight Z71 this afternoon. Sure do like those black wheels. Mine may get a similar treatment if the wife doesn't find out first. ;)
I just bought a 2017 Z71, has the 20" wheels and I would like to possibly install wheel spacers, fender flares, and bigger, wider tires on the stock wheels. Do I also need a leveling kit, and what's the biggest tire size I can run without rubbing?
Thanks in advance
Thanks in advance
Dan,
Just be advised that there are GM warranty issues with the addition of lift kits.
What is the difference in the Rough Country 2" leveling kit 1307 (cast lower control arms) and 1308 (aluminum lower control arms)?
I need to know the difference in the kits itself if anyone knows. Thank you and Merry Christmas
Finally replaced my oem 1.25" blocks with 1.5" and without driving it yet it netted me a 3/4" lift. Will see what it settles to after a few miles on it. Did one side at a time and was not a difficult job at all. Took me about 1.5 hours without power tools. d297efe1b5153d6eabe5ab50e14516c6.jpgb491f7f31bec36008e9643d154d98406.jpgcc1665ddb9c55d35a07e6c289d99dbae.jpg1fa4839bed0462fb08abea1aae3ba843.jpg030e54e9b3392fd73753ab2554638032.jpg6aced05af1a710a61b803417a31e3499.jpg8237b37f12fd9597e430432c545cf48c.jpg9c4f2b0067d86fef682cb130f3c463e6.jpg
From what i have read, just longer bolts come with the aluminum kit. I bought that one before my truck came in and mine has steel arms. I didn't have an issue installing them.
Edited by CptMcSaug
where you able to reuse the factory U bolts
Yup! Still using factory U bolts. Remember how they said it was a PITA to line up the block with leafspring. That was my fear but not a biggy; simply make sure the shocks are not getting caught with the differential hanger and raise the jack slowly then with my other hand I was a able to move the diff a bit to position and bammm they snapped in together. ca5a3c0de444403d4d6ac6dc2d181817.jpgd5280277e0cda4058f3ded1ed50fe1e7.jpg
    DaleB
    DaleB
  • Who's Online   6 Members, 0 Anonymous, 1,361 Guests (See full list)
    • My truck is a ¾ ton but my placard also says 80 for the rear tires, I think I might have the upgraded suspension to the 3500 series maybe.   I put my air down to 60 and the light was still on, and there was no way I was putting over 60 psi in the rear empty and not towing because I knew the actual number Toyo gave me and I didn't wanna ruin the center of my tires!   And you actually can change it in the settings from metric or is and it will show kph or mph then when you go into your tire settings it will be either psi or kpa, but it would be nice to just change it directly on the tire psi page
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
