No rubbing whatsoever!!! Parked I did full lock to lock and I had an index finger between tire and wheel well liner. I was thinking about going with a 295 but I called rc and they said trimming would be required and also the place I took the truck to to install lift said they wouldn't recommend anything larger than a 285. I'm very happy with the end result and glad I didn't go with a 295. It's The perfect tire size for this truck
Thanks for quick response. What about clearance between the UCA and Swaybar at full lock-to-lock. Is there any rubbing on the inside face of the tire?
I honesty didn't look, but I couldn't see any rubbing anywhere when I was looking for wheel well rubbing. Tomorrow I'll take a look and double check for you
I honestly doubt that rough country would put out a tire size for a stock wheel configuration that would even come close to rubbing any major suspension components.
285 65 18 will clear everything on a 2.5" level with wheels with factory offset all the way up to -6 offset on aftermarket 18x9. -12 offset you will have minor rubbing on the felt but fixable with a zip tie.
I will be interested to see what 4emeryj44 reports back with. I'm running 275/65 Nittos and at FULL LOCK, I can't get a finger between my inner sidewall and the UCA. The Swaybar probably has 3/4" or more before it touches the tire.
I don't think many people realize that inner sidewall rubs the UCAs as it probably doesn't cause much vibration or noise.
That's strange because my friend barely touches the UCA and hes running 305 50 20's on factory wheels which are like a +27. Sounds like the steering isn't centered unless it's real tight on both UCA's But if there is a huge gap on one side and not the other the steering is out of whack. Factory tires are 275 wide for a 20 there should be ample clearance between the UCA's
Both sides are even...my truck has had a complete new steering assembly put in it...and many alignments by the dealer (before and after the level). Tire wear is perfect and they rotate every oil change...I get 3 years free service at my local dealer. I've been lock to lock and held with a bungee to measure both sides many times as I've wanted to be sure before I get new tires. The clearance is very small at stock geometry...that's why I think 295s and 305s are rubbing more than people think on stocker 18s. I know 295/70r18s will rub both the UCA and swaybar on stockers unless you run at least a 1/2" spacer--there's several guys on here running them.
It's 18s that cause the problem with UCA clearance as 20s put the bulge of the tire a little bit more up and forward and away from the UCA. It's why you can usually run stock 20s with a knuckle lift, but not 18s....the extra height clears more. 18s require 1" more of spacer for knuckle lifts.
For all the guys out there with stock 18" wheels...275/70/18 fits great with a RC 2" leveling kit. I couldn't find much info for 18" wheel and tire combos, so there ya go. I am running 275/70/18 toyo open country at ll, with no rubbing, no trimming and its drives awesome.
That makes sense, i have never seen what the factory18's look like as far as clearance goes. My truck had the factory 20's and I swapped them out first for 18x9 -6 racelines then for the 18x9 -12 fuels that are on it now so UCA and swaybar clearances were never an issue clearance around the rear of the wheel well dictates tire size at that point. It would seem a 0 offset in an 18 is probably ideal for clearances around suspension parts and the wheel wells I just don't like the 20's unless the tires are 35" or bigger, both from a looks and functionality standpoint. Showing my age I guess I don't understand the point of running a 33 12.50 on a 22 x 12 inch wheel, looks dumb IMO, rides like garbage and zero functionality i guess I got to the point where I don't care if I'm cool anymore.
I'm running the same size 275/70 BFG KO2 on a 2" level and stock wheels. No rubbing or trimming, even offroad its still perfectly fine.
Edited by tyrich88
That size will fit without a level. The problem with that tire is how narrow they look, especially on a stock rim. Great side profile, but not so beefy coming and going. IMO, the 285/65r18 looks more 4x4ish even though it will be up to .5" shorter.
I am running 285/65R18 Toyo OC ATII on a RC 2.5" level and there is no rub at all. IMO it looks great
do you have pics
Hi everyone. Been lurking for a while and now I'm ready to pull the trigger on a level for my new-to-me 2015 LT Z71 DC. My measurements from the ground to fender lip across the center cap show that I have about 2.75" of rake. I don't mind there being some, but right now my nose is in the weeds. That and the tires kinda make me mad I paid for a z71. That z71 ain't what it used to be. Live and learn. I've had the truck about a month and I don't particularly mind how it rides, it's just too low in the front.
Ultimately, I'd like a 4" lift, but for now warranties and not causing damage to the truck are more important.
I've been bouncing between the RC 2.5" and the Bilstein 5100s. I know that the RC is a little extreme for a leveling kit, but I wonder if 1.85" will be enough level to look good. Also, do I need to worry about driveline angles with the Bilsteins? The price between the two isn't a factor in the decision. I'd also put the bilsteins in the rear if I did the fronts.
Can anyone give me some advice?
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
    • Atlas, you kill me As aggravating as a project like this can be you have been unable to hide your fascination with learning and using that angst against this beast like a Ninjitsu Master. It amuses you, admit it now.      BTW, love your writing style. 😉
    • I gotta say, I'm enjoying your narration. The troubles you've been having are amusing as you describe them. It's good to see that you're finally getting some satisfaction out the old beast though.
    • Declaring victory would upset the demons that possess this Blazer, so I won't. But I did make progress today--after it put up a fight. Always a fight.   I had the day off so I spent the morning cleaning up the shop and I thought I'd get ahead of things by filling the cooling system in prep for the final part I needed to arrive: the driver's side knock sensor. Glug, glug, glug....and then the unmistakable sound of liquid hitting the shop floor. It induces the same chagrin when the sonar and targeting laser temporarily malfunction during a late night bladder evacuation over the toilet with the bathroom light off. D'OH!!! That made a mess...   Oh, hey, that knock sensor I removed? It threads into a wet port. Who knew?! Learn something new every day. Put a pin in that chore, I'll fill it the rest of the way later.   The knock sensor arrived at about 1pm. I threaded it in, connected the wire, filled up the coolant, checked for leaks, and... drumroll.... fingers crossed for a perfect start, excellent timing, model fuel trims, and ...no squeaks... Here goes.....   No, it didn't start. At all. I cranked it a few times and it wasn't sounding good. Furthermore, I heard leaking again. Jesus H Tapdancing Christ, stop leaking all over the dang floor. This time I had accidentally overfilled the coolant reservoir and the churn of the water pump via cranking caused a bit to burp out. Ok, just, breathe... Put the flamethrower down. Dang thing wouldn't burn anyway, leaks too much...   Did you know the rotation of a round crank sensor in a round hole, matters? I do now. Took me about half hour to retrace steps and realize what I had done. Then it started right up.   No squeaks. The squeak was the old balancer.   Once it entered closed loop, fuel trims are dead on, hovering right around zero at idle. No more -30%. I'll credit the injector rebuild on that one.   Timing? I think there's an OBD 1.5 translation error with my Actron scanner. It's anywhere from -20 to -30 at idle, sometimes as high as -40 cruising. Sorry, the engine just isn't running that smoothly at -40 degrees ignition advance. It's just not. It's smooth all through the rev range and has decent power. I'm going to have to trust the seat of my pants on this one.   The new exhaust is very quiet. The old catalytic converter? Not melted, but definitely not healthy. Rains glitter when you turn it on its end...all the precious metal is flaking out. Once the new exhaust system burned in/smoked off a bit, the engine's exhaust smell is normal again. Not that I'd recommend going around huffing car exhaust, but, you know what I mean?   One problem to correct. The new exhaust has the opposite problem of the old spliced up exhaust. It wants to hit the floor where the old one wanted to rest on the cross member. Happy medium, please? Still noodling on that one, need to look at how I can adjust some hangers.   I don't know what's next. On one hand I want to run away from this thing as far and as fast as I can -- there have been a lot of NOT fun moments. On the other, now that it kinda drives nice, maybe drive it around for a little bit?   Shhh... it's not currently dripping oil all over the floor. I can see just a little wet at the bottom of the timing cover where it meets the oil pan seal. It's not dripping multiple drops with every ignition cycle, in fact, after some driving this evening it has yet to even form a drop that could drip off yet. But the weekend is young... I fully expect this could turn into Exxon Valdez by Sunday. Because this Blazer hates me. LOL.
