Mine is a 2014 LT 4WD. Measurements are 38 5/16" rear, and 36" front. The 2.5" level will apparently set me nose high. Will it settle enough to be level or should I just get new rear blocks if I get the 2.5" front?
That's just the front
yep ready lift with 33s
I just ordered a set of 2" spacers from Summit Performance on ebay. Really good price so we'll see how they work. If it's not enough I'll order the 1/2" top spacer.
I recently purchased a 2016 Sierra Denali. I want to level the front but the more I read I am less confident on what all I really need to do. I went to a local truck place today that sells truck parts and does installs and spoke to the guy there. He quoted me about 240$ to install a new set of torsion keys to gain the 2" i am looking at to level the front. My main question I guess is, is going the torsion key route any better or worse than say just adding the blocks under the suspension or any other way? Also, my Denali does use the magneride suspension so does anything need recalibrated afterwards or just an alignment and I'm good? I am just mainly concerned with dramatically affecting something that is going to have bad long term consequences. Especially with the magneride suspension, I just want to make sure that any sensors that need to be moved or recalibrated get taken care of correctly. Thanks for the insight.
Is your Denali a 1500? Because the torsion bar keys would only work on a 2500. The 1500s have used spacers since 2007.
I am getting the 2.5" suspensionmaxx installed on Friday, I know it has been covered a few times but I have held off on getting tires since I want to know the best (biggest) tire size to run without major trimming. Based off a few of the set ups on here I am planning to run 275/65r20 on the factory wheels (+27 offset) yet does anyone have any more insight on this? Would I be better off going a different route?
After receiving and reviewing the kit, I did not install the suspensionmaxx on my truck. The shims are flimsy cheap plastic, felt as if they would give just tightening the strut down. The kit has been sent back and I got a 2" Readylift kit in the truck now.
Torsion Keys will not work for your truck, you will need a lower front strut mount extension (some kits use upper as well). Some of the kits account for magneride and provide sensor relocation brackets, others you will need to have the system recalibrated. check out this thread for a better idea
http://www.gm-trucks.com/forums/topic/168618-leveling-kit-for-2015-sierra-denali-magnetic-ride/page-3
Rough country 2.5" with rear blocks- 285/55/20 Toyo RT's on OEM GMC SLT polished wheels
  • Like 3
Looks good! Have any side pics
And are you running a 2" rear block? Truck looks extremely slick!
Edited by Spate47
Thanks! I need to get a side profile pic.
I actually forgot to take a before picture so the only one I have is terrible but here it is before and after!
    B07
    B07
  • Who's Online   1 Member, 0 Anonymous, 803 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
