Thanks! Sorry for all the questions
No worries, glad to help if I can...
https://uploads.tapatalk-
cdn.com/20170510/9695dc7dfd6da7dc4447d028dd6ee644.jpg
Hey what psi do
You run your bags at when you tow
varies with load. Usually 5-20psi.
Finally got my level and wheels and tires! Couldn't be happier with the results.
Motofab 2.5" front and 1" rear
17x9 -12 offset with 295/70R17 General Grabber x3's
All I did for trimming was cut out a little piece of the rear of the front wheel wells. If done clean enough, you'd never really even know if was done. No rubbing of any kind
  • Like 5
Those tires are my favorite, trucks looking good
How do you like those tires?
All I did for trimming was cut out a little piece of the rear of the front wheel wells. If done clean enough, you'd never really even know if was done. No rubbing of any kind IMG_0444_zpscqqjr1gu.jpgIMG_0448_zpstxqcntwz.jpgIMG_0446_zpssvgmuqlo.jpgIMG_0440_zpsv5iaejlf.jpgIMG_0447_zpscnognf3j.jpg
You mean their 2"rear block? ;)
So far I really like them although I haven't put too many miles on them. For an MT they are very quiet but most brand new MT's usually are for a little while. And as far as rear blocks go, there is way too much confusion because of people using the overall height of the block instead of how much lift your new block will give you. all the lift blocks I found were labeled by how much lift they will give you ??
So far I really like them although I haven't put too many miles on them. For an MT they are very quiet but most brand new MT's usually are for a little while. And as far as rear blocks go, there is way too much confusion because of people using the overall height of the block instead of how much lift your new block will give you. all the lift blocks I found were labeled by how much lift they will give you [emoji1360]
I want those tires in 35 but I can't find them lower than $530 Canadian not including tax or additional fees 993142b1135d512d85c93b1a95b7a69c.png
From what I've gathered, General is discontinuing that tire and it's being replaced by the X3. Tire rack just had blow out sales on that tire in all sizes and most of them are all gone so I'm assuming that's what is happening.
yeah I haven't seen those around I was thinking of getting those with my new 17s but I'll probably just stick with toyos again. I'm hoping some place will have a great Memorial Day sale on tires
Ya I did see general has a new tread pattern A/T with the red lettering.
Yeah me too they remind me of a cement truck tire. The new x3's like mine are actually MT's not AT's but IMO they are kind of right inbetween the two which is why I like them. The x3 is supposed to out perform the old Grabber in every way tho.
    tararebecca
    tararebecca
  • Who's Online   3 Members, 0 Anonymous, 633 Guests (See full list)
    • I agree, simplicity and reliability matter more as vehicles get more complicated. A V8 work truck option with fewer electronic features and a stronger warranty would definitely appeal to a lot of buyers who use their trucks for real work. Customizing it with trusted outfitters is often the best way to get exactly what you need.webcrimsNY
    • I’ve heard similar complaints from newer vehicles where the factory “premium” systems don’t always live up to expectations. A good installer should be able to improve the sound without turning it into a bass-heavy setup. I’d look into upgrading the front speakers, adding a quality DSP amplifier, and possibly improving sound deadening first—those changes usually make a much bigger difference than just adding a subwoofer. Hopefully someone local can recommend a reputable installer in the Las Vegas/St. George area.
    • Do you remember that Harley Davidson was more successful (solvent) when it produced about 60% of the market demand (by design) and forced wait times of up to three years? Even when your turn came around it was, "Take what we are giving you or move to the back of the line and start over". HUGE markup's were 'normalized' and dealer killed. 40% markup and no floor plan? What's not to love? Greed will kill them yet. They have surplus production and customer base is tanking. And still they think nosebleed pricing will work.
    • The engine was done as part of the 6.2 recall?   You'd have to see if your VIN also has the 6.2 engine special coverage on it.  Coverage number is N252494003.  If you have this, your engine is covered under this and NOT the GM replacement part engine warranty which is 3yr/100k from the date of install.  The 3yr/100k mi warranty is in effect for non warranty purchases.     This is not any different if it was replaced under warranty without a recall or special coverage.  So if you had a 5.3 and it popped at 3 years in at 50,000mi during the 5yr/60k powertrain, the replacement engine would not get the 3yr/100k, and instead gets the remainder of the 5yr/60k as coverage.     So N252494003 gives 10 years or 150,000mi of coverage, which ever comes first, starting at the vehicle in service date.  So if your in service date is 01/01/2022, N252494003 gives you special coverage of the engine until 01/01/2032 or 150,000mi, whichever comes first.  So if your start date was 01/01/2022, you'd have left 5 years and 4 months (lets round to august 1st), or 62,000mi left of coverage.   So you need to know your in service date to know how much coverage is left.
    • Okiee dokie there bud, way to take things to the extreme.   I guess you missed the whole point and take things way to serious. I installed different EV6 style injectors that just so happen to be larger in my car running the same LQ4 engine and with a better spray pattern than the stock style injectors and I noticed no difference in the idle quality. Kinda was my round about way of saying that even if you put the same size but better style injectors in your truck, you will likely see the same thing.    I'm sure you're great to have conversations with in person if that's how you act through a keyboard. One little things sets you off and now I guess my dick is all up in your face.
