I haven't seen anyone run 35's with a 2.5 level, much less a 2". If you find someone running them with that, please report back. Even stuffing 34's in there is really pushing it.
I found the email from the rep
The trucks clearing 35's are F150's and Rams with round wheel well openings. Don't think a 2014+ 1500 GM truck will clear 35's without rubbing bad. Need at least a 4 inch lift to clear 35's.
2.5" RC, 275/65R20 Ridge Grapplers, Stock 20" wheels plastidipped matte anthracite grey to see if I liked the color. Turned out pretty good. I do have airbags which put my about an inch higher in the back, if I drop to 0-5 psi it runs almost perfectly level
  • Like 5
I'm gettin the RC 2.5" soon, trouble is, I can't decide which wheels to go with for my tungsten metallic.....apologies for the minor threadjack
I just went matte anthracite grey on my stock wheels, I think it complements the color very well, something different from the typical matte black
Question...
I've got a 2014 Z71 that I just purchased at "Ready Lift - 2.25" Leveling Kit."
Seems pretty self explanatory on the install, but I'm just curious about the "2.25"
Looking at the round spacers, they are only about an inch thick. And the little "C" shaped spacers that go on the bottom are only about 1/4".
Where are they getting 2.25"?
Thanks in advance.
Mike
Because of the geometry of the suspension components, the leveling kits are not a 1 to 1 lift ratio so that sounds about right. My 2.5" front upper spacer measured less then 2". 1 11/16" if I remember correctly.
The 999901 is the Gm quick lift, I gave them all my vehicle info for my 2016 GMC
look forward to seeing your truck when installed!
My 2.5 inch level kit lifted All Terrain rubs slightly with 33's when reversing and turning full lock. Have not driven hard off road but I'm sure it would rub the inner fender on a big bump at speed. Your best bet is to test fit a tire before buying them and turn the steering wheel lock to lock. 35's may fit and cause no problem when running straight but factor in a bump while turning and you may end up either trimming/sculpting your fender to get more room. Good luck with your mod and post pictures when done.
Edited by Lgetz
That's marketing, plain and simple. Their website doesn't specify what make/model the 35's can fit on, or what width the tires are. "Up to 35 inch tires (on select applications)" isn't the same as saying "will fit 35x12.5 tires on GMC 1500 4WD, with a max of 4.75" backspacing on the wheels". As someone already mentioned, that 35" claim is likely on a different make of truck.
Looks fantastic [emoji1360]
That would be great - everyone here does the 3.5 on stock wheels
3.5" lift? 35" tires? I'm not sure what you mean here.
Edit: nvm, just saw your post above. I got confused when you brought the wheel comment into it.
Edited by corncob
Thank you.
Just being less than an inch thick, just seems a little well, not right. But, this is what I got from Ready Lift.
Thank you.
I have the same level
Ground clearance
Top of tire to flares
Front to front
Back to back
Inside
Edited by SuperSierra
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
