I'm running 305/55R20 toyo open country at2 extreme on stock wheels.
Wow! Looks good, and with just the 2" level up front? I might be changing my mind... Do you know the width of them wheels? I got to do some new research... My Hollander 5308's are 8.5" wide (I believe) and have a 31 mm offset. If them tries fir on 8.5" wheels I may have found my next set of tires...
Hello, new guy here! Thought I'd chime in and help any one out who's looking to go the Pro Comp route.
The Rough Country 2.5 inch levelling kit would have taken 2 weeks to get in. I opted for the Pro Comp 2.25 inch Level with the 2 inch blocks in the rear instead. I've got some 305/55/20's sitting in the garage until I can decide on some new rims. I'm pretty happy with the level, as far as I can tell, the ride feels stock.
  • Like 4
Looks good man
Does anyone know if these level kits 2.5" or shorter work with magnetic ride without any modification? I called RC and they of course said yes, but it felt like the guy on the phone just wanted to sell another kit.
I'll be getting my 2.5 RC front only Thursday with 305/60r18 on stock wheels, I've seen posts where some say they will rub and some say they won't anyone know for sure?
Yes put the rs9000xl shocks on the rear. Love them. [emoji106]
Sent from my iPhone
using Tapatalk
Sent from my iPhone
using Tapatalk
What part numbers did you use for the front and rear rancho's. Think of getting the loaded 9000xl strut for front and using readylift 3" block in back to lift the overall vehicle and retain some of the rake and trying to decide what length shocks for the back.
Rancho
RS999901 quicklift front
RS999297 rear shocks
Sent from my iPhone
using Tapatalk
Rancho
Sent from my iPhone
using Tapatalk
U can buy them in pairs with these part numbers on eBay for a good price
Sent from my iPhone
using Tapatalk
Sent from my iPhone
using Tapatalk
just about to order off ebay, I notice they is a note on it that says " z71 will not have any lift with parts installed " is this due to them not knowing a z71 is no different height wise? or is this legit or incorrect?
thanks, im guessing you had lift after it was installed
I saw the same thing Bub...I have a LTZ z71 and was looking into the Quick lift also. I have an email into Rancho. Waiting for reply.
    TopBo
    TopBo
  • Who's Online   5 Members, 0 Anonymous, 1,696 Guests (See full list)
    • Thanks!  I figured as such; GM and other manufacturers have used standard parts and harnesses across trim levels and such for decades.  I pulled the blank accessory cover off of my commuter van (a 2016 or so Chevy 15-passenger) years ago and found the plug for a USB outlet.  It wasn't connected to anything, though (I tried swapping in an outlet from another van).  I was a GM Tech years ago (late-90s) and was pretty familiar with my 2006.  I might be wrong, but I view newer vehicles (pretty much anything made in the past 20 years) as being a lot more plug and play.  Meaning, more unused wires and plugs unless you have the Mack Daddy of vehicles.
    • not all plugs will be used.  gm uses more generic harnesses that support most/all options, and if your truck doesn't have a specfiic option, the plug won't be used (commonly will have a dummy insert in the plug , or it'll be taped up, but some may just be left as is).  But it's sldo possible some p.o. has installed the wrong/cheaper parts that aren't correct for your vehicle...
    • First off, I'm not trying to just get easy advice/fixes for the issues I've noticed so far.  I'll be combing through the site via searches and such, and if past experiences are any indication, should find what I need.  For the sake of conversation, though, I figured I'd post the handful of things I've noticed in the 12 hours since buying my 2010 SLE CCSB.     Indicator lights: Airbag and TPMS.  The tire pressures aren't reading for any of the wheels, so I'm pretty certain the sensors were either removed, are damaged, or are otherwise inoperable.  I used to mount and balance tires 25 years ago but am pretty much ignorant when it comes to TPMS.  My 2006 didn't have the sensors and this might be the fourth vehicle I've owned that does.     Radio: Rear speakers aren't working.  I removed the driver's side rear door panel and checked the speaker and wiring.  I also removed the sill and b-pillar covers to check the wiring.  A few minutes of Google Fu showed that this is potentially a head unit issue.    Switches: Power mirrors don't turn left/right.  I ordered replacement driver's door switches that should arrive tomorrow.  The windows and locks work but it was only about $20 for all of them.  The driver's side rear window switch lets the window down but won't put it back up.  I think the passenger rear doesn't work at all.  In the coming days/weeks, I'll break out my multimeter to check all of that.   Unknown wiring harness: There's a box attached to the front driver's side of the engine compartment, right where the second battery shelf is located.  There are three plugs, one of which looks like it fits a standard headlight-style bulb (9007 or similar).  It doesn't look like it's plugged into anything.  I'll do some digging and if I don't see anything elsewhere on the site, post some pictures here.   Unknown plugs on brake booster: There are at least two female plugs on the brake booster that aren't being used.  I think it might be a replacement/aftermarket, so maybe those are used for a different application, as there don't seem to be any unplugged harnesses and no indicator lights are on.   Little squeaks when turning: Sounds almost like a bushing around the bed of the truck.  I'll have to pay close attention as I get more familiar with the truck.   Clunk on acceleration: possibly the infamous drivetrain clunk.  My 2006 had it and I'm just not familiar enough with this truck yet to fully grasp what it is.   Anyway, my apologies for the vague and all over the place post.  This truck is new to me, and it's been four years since I drove my 2006.  With 200k miles, I know I'll need to learn this truck quickly to avoid having any major issues, despite being confident it's got much more life to it.  My 2006 had nearly 320k on it when I parked it (nearly 300k of which I put on the truck), and it was still drivable then, though I suspected the head gasket might have blown.  I'd hoped to have that truck back by now, but it's gone forever, as I detailed in my reintroduction thread.
    • I always drive in Sport mode. With more driving, I am finding the initial response when accelerating is much quicker now🖕 Lou
