On December 29, 2019 at 7:58 AM, jimmyboy8301 said:
Lol thanks, it’s one of the few things she can’t destroy
I know what you mean. The dog I had before the one pictured above was a real chewer and the Kong was a lifesaver.
  • 5 weeks later...
  • 8 months later...
Our new protector
year and half old female German Shepard
love her to death but man does she leave hair everywhere!  ?
My 1.5 year old European Doberman Kane.
Beautiful, take lots of pictures with him, you’ll be glad you did. I miss mine enormously.
Our current pack, not so sure about the protection part, but they have their moments when they think they are tough.
Plus they have their own truck now, rough life they lead.
IMG_0819.jpg.3ec48dc38e0e0cecc9c390a1efb8627b.jpgIMG_0585.jpg.7c26202768c43a3ec2f81434100e7398.jpg
Love the plate on the truck.
That's allot of dog food.
:crackup:
:crackup:
It is, and that leads to a lot of poop, Huskies have an incredibly high metabolism, so in one hole and right out the other....
That is why they are walked once a day, helps on the amount in our yard.
  • Haha 1
Once a day!?  Try twice!  Good lord!
I'm dealing with my Sr. Citizen girl, Daisy- 10 year old going on 11, Lab/Golden mix.  She's a gentle giant who loves everyone and other dogs, but her vision is getting bad, and she's loosing a lot of of her hair which has the vet concerned.  She's already being treated for thyroid issues, so we are trying to adjust the levels after a recent check showed them too high.  I hope she stays healthy enough to be with me a few more years.  She's been a wonderful friend these past 10 years which have been hard on me.  Mollie on the other hand has made it thru a cancerous tumor and is doing well and very high energy at 6 years old.  A faithful "daddy's girl"  who gets jealous of other people and dogs around me but always softens up.  <sigh>  I plan to have a German Shepherd someday.  I love Labs, Goldens, Beagles, Australian Shepherds, and Border Collies, but I've always wanted a German Shepherd ever since having helped train several Police K-9s back in the day.
Here is my 10 year old Daisy.
84158703_127618828762637_4320807532944687104_n.thumb.jpg.c7d06e465a8cefe0d9dedde76a4224f1.jpg
Mollie as a Pup.  She's part Lab and part Cocker Spaniel.
Edited by Colossus
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
