Yes, ill get a pic of it.
As for the straight hoses, I was kind of limited by the length that they sent me. I'll correct it and give it more slack when I get the correct hoses and fittings for the job to be done right.
Good stuff.
Sent from Tapatalk App - Samsung S6
How much is everyone seeing in their catch can. After about 4600 miles I have collected a total of 4.1oz of oil. Does that seem low or is it normal?
I saw about the same amount from mine (Elite) a little over an ounce per 1k miles.
I just had a thought about these Catch Cans. So they start filling up with fluid, what if you hit some bumps and it starts sloshing around, could the intake take a big ol gulp?
I suppose that's possible, especially with the roads we have out here in Massachusetts ... but I'd never let mine even get close to that deep.
Yeah I thought about that as well and drained mine before I got down to the beach knowing I'd be 4 wheeling on the sand and bouncing around
Edited by Silverado-Hareek
About the same ride you get on any Massachusetts roadway ... :lol:
By March, there's way more sand on the roads in MA than there is on the beach!
More on-topic, while it's clear that the cans catch a lot of stuff, is there any evidence that it stops valve deposits? (Has anyone put one on one of those Audis that have really bad deposit issues and seen the issue fixed?)
Figured out my original question.
However, I have another.
I've read that the Elite Engineering clean side separator that goes into the stock oil filler location, is not a good idea if you live in cold climates.
Where I live, we see the extremes of both heat and cold. Can anyone comment on this?
Edited by Habs
I installed the Mike Norris can in my 2014 with about 4800 miles, this is what I got at 5600 miles. I was really surprised I collected this much so soon. I'm 100% sold on catch cans now.
My first 600 mile run collected 5x that much, but 90% of it was moisture, since the average temp at the time was 35°F. You guys on the left coast won't ever see that, with the warmer temps and drier air.
Ok, mine was mostly oil and the temps have been averaging 80-90°F
Those quantities varying by temp are typical. Here in VA, we have cold winters and hot summers. In the summer I'm getting about 2 oz of oil every 1500 miles. In the winter I'm getting a 6 oz. mix of oil and water every 600-700 miles. On average.
    Whit.the.COB
    Whit.the.COB
  • Who's Online   4 Members, 0 Anonymous, 457 Guests (See full list)
    • Even tougher is the 5.0 / 302. That's what this one has.    https://postimg.cc/Z9XRrCSg   https://postimg.cc/4n3F3yzY   Just realized I had the airbox removed in the engine pic, lol.
    • Yep! This should be a pin somewhere as @pgamboa really dives into all of this. Thanks for reposting the link!
    • I did the new thermostat after doing a 'flip' for a year. Runs as cool one way as the other in the summer but in the winter there is a bit of a floor. Yellow with the new 70 C thermostat. My data over the life of the unit to date. Still need more cooler. Anyway that floor helped both winter fuel economy and shift quality in the winter. I found it a good balance.
    • Evan Williams Bottled in Bond   So pouring the last of a bottle of Evan Williams Black label last night I set off the the state store for a refill only to be denied the by an empty shelf. Rats.    What the did have was a bottle of Evan Williams Bottled in Bond. 100 proof. Hum, a few bucks more but a known distiller. Lets have a swing at it. ( I have before )    Cracked it open and pour a serving over ice. Hum.... more heat, yes. More alcohol naturally. But the barreling not the proof brings the taste and this one came up short.    Oh is was familiar but the heat ran the barrel over like a Peterbilt runs over a squirrel. Could use a heavier toasting of the oak me thinks or perhaps a longer barreling. Who knows. But what I can say is ice or a water back isn't the answer. What kills one kills them both. Sad. It is a pleasant drink....if you have little to compare it to.
    • I've had exactly one set of Bridgestone. Lasted five year and 125,000 miles and had I known better 15oK would have been a cake walk. I would have bought a like set had they not tripled in price since the first set. I removed them at said mileage with 5/32" remaining in dead even wear all four. They were fuel efficient, quite, comfortable and predictable.    Early on I got a very good alignment checked at least once a year, sometimes twice; kept the tires properly inflated, balanced and rotated. And I've found that many a tire issue can be avoided with great maintenance practices. Lot's of tire dealers will do rotation and balance (simple) for free for as long as you own the tire they sold you so no excuse not to.    Bead prep, alloy integrity and stem health have a huge impact on inflation stability. There are more mountings done poorly that perfectly. Finding a good tire guy is gold and as important as finding a tire you like.    That 3X price increase now two sets of "other tires' later is starting look like a bargain.      Bad maintenance kills more tires than bad tires.
