I added mine before our trip to North Carolina and I collected this much so far (1080 mixed highway/city). I also added some stainless media to catch a little more.5e48194216a627bd3fdf0ceb516cb19a.jpg
Sent from my SM-G920V using Tapatalk
Got a trip to FL coming up - I'll see how much I end up with after that. Should be close to 2k miles round trip.
This is a long thread so I don't know if this was mentioned before but I took the connector ends out of the old PCV line and inserted them into the new line. Looks like an OEM installation and seemed to take some of the hiss out of the system for some reason I can't explain.
Ordered an Elite Engineering CC and clean-air separator today... plan to install this weekend with my first oil change (got 5100 miles now). We'll see how it goes.
Putting Amsoil Signature Series in FWIW.
That's the oil I run. I ran mine HARD towing at least 15 or so loads over 6k lbs. combined trailer weight for 14 months and 9700+ miles. Last oil analysis showed I need to change it a bit sooner next time. I wasn't surprised. If that was conventional oil, I'd have had to dump it at 1,500 I bet.
This is what I run with a Wix Filter
Sent from Tapatalk App - Samsung S6
Was thinking about the Wix too... how do ya like em? I've been using Mobil 1 and K&N for years.
I've been using K&N filters, since I bought a huge lot of them when I first took the truck home. I don't think they're anywhere as good as Wix or Amsoil EA - that could account for some of my high levels of iron and aluminum too. With K&N your basically paying for a heavy case, and a 1" hex for easy removal. Not sure how good the media is on those. Haven't looked into it .
[DELETED. Damn double posts on this site!]
Edited by Jsdirt
Been running Wix for 3yrs, love them and the analysis reports.
I wouldn't go for more than a year if my only driving was to church on Sunday. You'll get moisture in there, especially given that you're in MA with winter and all. I suppose you're keeping an eye on it with OA, but without that I just wouldn't go for more than a year.
That's the reason I changed it and sent it in. Came back with negligible moisture content. Wasn't the length of time, but the high levels of wear materials from heavy towing that require more frequent oil changes.
Some of my OPE will go 2 years or more on Amsoil Formula 4-stroke. My ATV has gone 3-4 years. There is a moisture concern, but if you use the equipment, it boils off. The one year thing pushed by oil salesman is to sell more oil. I base that on my own experiences.
Your order will be assembled and shipped today.
Thank you!
:thumbs:
My Catch Can makes a audible hiss that sounds like it is coming from the intake. I drained it for the 3rd time today and got another half ounce. I am amazed at the oil I am catching with the Elite Engineering set up. These engines slobber worse than a 2 stroke LOL
Thanks to this thread and having prior info, I purchased an Elite can and installed on my Silverado with less than 50 miles. I am truly amazed how much I have collected in less than 2000 miles. Really makes me cringe when I see so many Chevy/GMC's driving around and probably less than 1% of people have one.
    • I have a 2024 Chevy Silverado 2500 with the 6.2 liter engine, Vin: 2GC4YME79R1273849, with 27,437 miles. Recently we took a trip from Candor, NY to Townsend, TN pulling our fifth wheel, when I got close to the Townsend, TN area The truck gave me a message of low oil. I checked the dip stick and found it was 2 quarts low. Today, August 27, 2026, I had the oil changed and the technician Found the truck was very low on oil.  Is there a Recall for this? What is my recourse for this issue? Do I call the dealer where I bought it or any chevy dealer?   Robert Strickland 292 Owego Road Candor, NY 13743 352-502-6588 [email protected]
    • We understand the importance of understanding how your Sierra performs, @SoCal Angler. Our team would like to gather the proper details to assist you with your inquiry about your truck's automatic braking. When you have a moment, please visit: https://s.chevy.com/support-request and fill out the request form with pertinent details. This will ensure your request is routed correctly so we may take a further look. We will keep an eye out for your outreach.
    • That is the funnel kit I bought and for being here in Canada I did get a better deal than what other sources were charging through a certain supplier in town that sources more directly and they ordered it for me. There are other items now on the market which would be perfect as well but this has worked well which was the hope when I bought it. I mentioned the Amsoil quart bottles as they have that squarish shape up top and it props nicely on the rim of the opening without falling into the funnel so I can leave them sit and drip a bit. You may have already figured out that to get the cap off the valve cover unless one is 7 + feet tall its not going to be reached without standing on a step of some sort and so when I do that I put the right adapter in and just leave the elbow on the funnel all the time anyway and open the lid and then if using quart containers for sure I can stand beside the truck and leisurely add the oil, and I can leave that funnel on when starting the engine to let it idle to fill the filter and then add the rest of the oil to top it up before removing the funnel and putting the factory cap back on. I put the cap back on the top and slide the bottom cap on as it fits onto the elbow adapter also and then store the funnel in a clean household plastic garbage bag along with the adapter so I have no reason to be washing out the inside of the funnel as I keep it completely clean between uses.    Draining the oil as per the under the truck portion, yes indeed that is slick as someone was thinking on GM's part there and admittedly I don't drop the oil screaming hot in this truck due to the exhaust being there and makes it safer as far as the oil temp if its just warmed up some instead as I don't have the truck on any ramps etc as I do it as the tires sit on the garage floor. The filter is not boiling hot then either and can drop it off into another pail after pulling the drain plug and just leave it drip out. Go back under a few hours later with new filter in hand and clean off the filter base and put the new filter on and install the drain plug. The filter is a little cramped in there as per wrapping ones hand around the filter and I am so used to using the band style filter removal tool that its no big deal and same for snugging it up. My filter wrench is many years old now but I think this is the current version and sounds like the right size, just in case my explanation was not great ( those nylon strap wrenches that one tool fits all filters are not my favorite tool to use, I much prefer this style personally )     57020 Swivel Gripper - No Slip Filter Wrench - Small | Lisle Corporation   And again about the oil draining and filter setup under these GM trucks, I've watched Ford videos of them struggling with oil flying sideways out of the oil pan on the gas 7.3 due to the sideways drain plug onto other components or cross members and guys trying to make shields out of carboard etc and other Ford pickups that Ford insisted they have sideways drain plugs. One win for GM there anyway with this engine.
    • Kind of off topic, wife drives a 2023 Yukon Denali with the 3.0, been a great rig so far, incredible fuel economy for a truck that big and heavy. Coming up on 50000 trouble free miles.
    • I`m gonna try some of this in my 2000 LM7 that has had the famous piston slap since 17,000 miles or so. I have used Mopar combustion chamber cleaner down the spark plug holes a few times in the past. Corrects the problem for a few months or so. Then returns. GM top engine cleaner has been used also. No good results from this.   This LM7 never used oil. Even running the piss out of it.   Course, I`m gonna use this in my 2025 L84 while it`s still clean. It`s got 13,000 miles. Used Chevron fuel system cleaner [2 bottles in tank] a tank or 2 ago.
