After several shipping delays, yesterday I finally received my new 2014 Silverado LTZ Z71 Crew Cab.
Beautiful truck sir! Got any interior pics? I absolutely love your truck!
Thanks! I have had it for 24 hours and am pretty stoked.
Here are some interior pics:
2014 chevy silverado, 6 inch pro comp lift, 35 inch nitto trail grapplers, RBP wheels, amp power step
  • Like 5
Nice! That's pretty much the interior setup I think I will go with when it's my time.
What state are you in? Snow/salty roads a concern with those amp steps?
Sent from my DROID RAZR HD
I live in NH, lots of snow lots of ice and lots of salt haha. They have a safety that stops them if they hit resistance so hopefully not, but they come with a 5 year warrantee so I think I'll be okay. But they are a wicked pain in ass to install just a warning.
My installer said that the use of mud flaps helps a lot because the snow/ice buildup stays in the wheel well rather than under the front door.
He did say out of the hundreds of AMP installations that he has done, he has only had one failure due to ice build-up. It was on a lifted Jeep with huge tires and no mud flaps... the guy was an off-roader and he was told that the AMP's would not be recommended for his vehicle... he proceeded anyway and the motor on the driver's side bound up and failed the first winter.
It's just common sense to me that if you're in conditions where large amounts of ice buildup are a problem, go with fixed running boards rather than power.
I'm in NH as well. Ya, I've heard mixed reviews so instead of dripping $1000+ and having them fail, I like to heat from everyone. In realise they have a warranty but the goal would be to never have to use it!
New pic with the 2.25" Ready-Lift Level Kit and AMP Power Steps.
Updated pic ... All cleaned up with AMP PowerSteps (OEM Assist Steps gone!)
Sent from my SAMSUNG-SGH-I747 using Tapatalk
Nice truck. How'd you get the Silver GMC logo upfront?
It's black plasti dip. 4 coats + 2 coats glossifier.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
