details on lower grill light...
i like that - very subtle...
It is a Rigid SR 20" - Combo. I had a custom shop where I live install it for me. It was all custom work and I'm not sure of all the details but I made sure it was solid work. It was the first one they have ever done. It turned out better than I thought.
Thanks man.. I almost wish I would have gone white like yours. The white is just so clean. Yours is solid.
I appreciate it brother. If I didn't get white, I would've went black lol. I do like your light bar though. Unfortunately here in Texas we have to have the front license plate. Not saying yours isn't bright enough, but if you want some more, you could throw another one behind your grill lol
09F1AB74-AE77-4449-80A3-5A25A9660A9E_1.j
761D6C79-1969-43B5-807F-A75337213CCF_1.j
That looks really good. How's the light output behind the grille? I already get flashed by people just from my Morimoto HID 50W in the headlights. If I can't see I just turn on my fog lights and the whole road lights up but I get flashed a lot, lol. The light bar is almost overkill but screw it, haha.
Your HID's might just be aimed a little too high. I have same setup and I get flashed every now and then, but not very often.
Really don't lose much output at all. Lights up everything in front of me to about 100yards away. Hard to get pictures that do it justice, but this is the best one I've got. Still much brighter in person, but you get the idea
5000k 55w lows/high
Low/high and lightbar
5000k 55w lows/high
Yeah, they are a little too high. I need to adjust them soon. That light output is really good. Truck looks good man. How big it that light bar? I'll try and get pictures of my lights soon to post on here.
It's a curved 30". Anxious to see your output pics
What are you running for tires? Size? rubbing?
305/55/20 Nitto Trail Grappler. I have some rubbing at full lock. I'm just careful to not need to turn at full lock. I am trying to figure out if I need to get a 1/4' spacer or a 1/2' spacer to fix the problem. I plan to get it figured out over the next couple weeks.
Here is the Low beam
Here's the Low/Fog
Here's the Low/Fog and Light bar
Here's just the Light Bar
Here's just the Fogs
Not impressed with the light bar but it is only 20' and it's at the bumper. The fogs are what makes a difference.
2015 1500 6.2L SLT 4x4
- BDS 6" lift
- Toyo M/t
- RBP 99R
- Amp steps
- Flowmaster exhaust
95329452-B98D-4D77-BB6D-8087C6C3338F_zps
146D1BA6-7519-4433-84D1-2FD475AF7CC4_zps
Are you from Houston? I noticed the gay family auto plate.
Sent from my SAMSUNG-SM-N910A using Tapatalk
New shoes for the girl...
62381B4B-93D3-4173-9B71-4EF08E8C8ECF_zps
909853D8-02B7-4F80-82CF-45C3BA5755A8_zps
2E73B37C-F1EA-4C7E-AFF6-62FEB3C68B36_zps
How do you like the rt's?
f0538881eab79f10baf1873e05844a8d.jpgjust to participate.
Sent by a simpleton struggling to operate an iPhone.
What lift and size rims and tires do you have ordinance?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
