Finally purchased and installed my cover. Ended up going with a Diamondback SE version. Was debating on the HD version but couldn't justify spending the extra $400. So far so good. Sits flush and so far no leaks. ANDDDD, as an added perk, feels like it adds just enough weight to the bed to level the weight on wheels....might be just my mind but still, pretty cool.  Can't wait to add the extra cleats I bought and start playing with the cover. As an added bonus to my already happy mood....come to find out....the bed extender works perfectly and fits perfectly under the cover!!
What's the name of that bed cover there and who sell it.
Looks real nice
Looks real nice
Never mind I got my answer.
This is a good looking truck. What's your setup?
Thanks !
2017 SLT - dark slate metallic , painted the bumpers same car color , changed to Denali grille - 4 inch ready lift - fuel nutz 17 wheels - bf 315 tires - borla atak dual with dual straight black tips - hd mirrors and ( Texas edition emblems )
2017 1500 z71, 3.5 RC knuckle lift, TOYO RT 285/65/20, aftermarket towing mirrors, custom cab clearance lights.
Got any pics of your suspension angles up front? Been wanting to see them for this kit for awhile
Loving the gas mileage with the 6.2.ca9cf47dd25c4f21e4332e1eea9977e7.jpg6cfc018e8a6ceb70bb381091eff5034e.jpg
For sure, give me a few and I’ll send some your way.
Wish mine would do that good, according to the onboard computer.
    Randy Ginoza
    Randy Ginoza
  • Who's Online   4 Members, 0 Anonymous, 1,803 Guests (See full list)
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
