I may have figured out how to get it. Kinda hard to explain, but basically it'll be a mount on the differential bolt that will drop down low enough to clear the actuator and have the correct geometry with the steering.
Got fog hids for sale. You know you want them
They won't do any good in my stock housings. I'll post a pic of the pattern sometime, it's pathetic lol
How much and how bright?
Sent from the toilet
They just sold on the SS site. But they were the brand of yours 55w 6000k. The guy also bought the 55w 6000k's in my highs and lows
Edited by Chris
It was on here like 2 hours before I posted here. But only lasted like 30 mins there
Installed the Hella lights today. It doesn't look like it in the pic, but they are a more focused beam than the factory brights.
4646446F-730A-4D8F-A549-13DEB7390437_zps
1FCE2416-D084-4F03-AB73-B4DF814883E3_zps
The reflection in the first pic is in my lens, not in the truck. :)
Edited by kstruckcountry
Had my first night drive with the extra lights tonight. I'm pretty impressed with them. They extended my range quite a ways, and I can see reflectors from even further away now. Closer to the truck with the brights and aux lights working together, it's lots brighter and far easier to see. I'm happy with wiring them up with the high beams, it's very convenient to have both sets come on with one flick.
I remember I had 4 KC daylighters long range on a light bar on my truck and would flick them on and felt like I could see more than half a mile. They were totally illegal for on road use and in my state you are only allowed a max of 4 lights on at a time up front. And then people would keep their highs on so I would flick em on real quick to give em a taste of what it feels like, good thing I never did it to a cop lol
Sent from the side of the road...
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
