2 hours ago, qwank said:
I have them on my 2017 with the stamped LCAs and they work just fine.
Awesome, thanks for the confirmation. What are your thoughts on the ride quality afterwards?
23 hours ago, Dub1796 said:
After lowering the rear of my truck with belltech shackles and block removal, i have decided i want to lower the front 1". Has anyone successfully used belltech lowering strut part #25004 on 2018 stamped LCAs? Belltech only shows that the drop spindles are compatible.
TIA
They're the same struts for 07-18
11 hours ago, SirenRed16 said:
Belltech vs Mcgaughys lower kit? Which one should I go with?
Sent from my SAMSUNG-SM-N920A using Tapatalk
Personal preference. If you read back through the thread, you'll find good things to say about each. I've got Belltech and am very happy with it, but I'm pretty sure I wouldn't have been disappointed with McGaughy's either. If you're going with spindles, you'll find more comments about McGaughy's and they're all positive.
Lowered my 15 all terrain with 2” drop shackles but it’s still 1 1/8” higher then the front. Anyone know where I can get a 1/2” block to replace the stock rear spring block.
they ride much better than the stock Ranchos
On 2/16/2018 at 11:24 AM, Nasty said:
That would be the worst thing you can do.  Using a strut and 2" arm.  That will make your front wheel closer to the rear of the front wheel well. Which looks ugly and more rubbing.  If you want 2 more inches you do spindles
Don't you loose turning radius with most spindles? Thats something im not something to sacrifice. I was trying to look at mcgaughys spindles but as far as i can tell their spindles (34050) are for 2wd/steel control arms? Mine is a 4x4 with aluminum arms/spindles.
The only setup on their site that i can see for a 14 4x4 requires upper control arms as weill (34204), if thats the only option i guess its staying at a 2 inch drop, not worth $1200 to drop an extra inch..  Any other options that im missing?
I'm getting my 3/5 drop incliding McGaughys 4x4 spindles installed next week, I'll let you know if the turning radius changes
Thanks, Do you know what part number your spindles are? What style control arms are on your truck?
The spindles are part number 34204, which do come with the upper control arm, and my control arms are the stamped steel versions. I'm using the 34155 kit which is the strut rings and spacers and the rear adjustable flip kit to get a 3/5 drop.
Would really like to see a pic of your truck from the side....I am considering doing the same type drop. I do tow a 5,000 trailer on occasion but don't have very much drop when towing.
Lastly did you do the work yourself or have someone else do it. I don't have the right toolset so I might consider finding someone to do it.
This is the only pic I have till I get home. I did it myself but I’m also a mechanic. So all my tools are readily available. Like others have said the hardest part is folding the bed seam but an air hammer made it much easier. Other then that regular hand tools can get the job done.
    • https://www.msn.com/en-us/autos/general/what-makes-this-1963-ford-falcon-red-rocket-special/vi-AA2asoRz?ocid=winp2fptaskbarhover&cvid=be9c1b4f79ff4211c526abd60f6da012&ei=16
    • True. My statement needs qualification. "For a shade tree mechanic, re-assembling the front engine to achieve a rough baseline timing of 0 degrees, as is approximated and indicated by common visual indicator mark alignment, measured with a human eye capable of 20/20 vision *with correction, I am reasonably confident that I have followed the outlined procedures/ prescribed methods for verifying baseline timing."   😉   In the end, the computer sets the timing, it's continuously variable based on sensor input, and the distributor only has a degree or two of physical adjustability intended for dialing in the final setting for cam ****** once everything is back together. But even that final value is acceptable within, I believe, +/- 3 degrees.   I thought my exhaust project was going to be a bear. To my surprise, the old clamps came right off last night, and I was able to unbolt all the hangers instead of having to muscle the rubber mounts. The old cat is ready to slip off the factory y-pipe. The rest is ready to come out with one or two cuts, and I've got a fresh blade waiting. I love living where rust isn't a thing.
    • I work at a Chevrolet dealership & hear it all believe me.  Just reads like there's going to be a fist fight over filters.  Can't get enough, continue!!
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
