On 4/14/2018 at 9:04 PM, qwank said:
I can live with that. I have a 10mm ring under the spring perch as per the instructions for non autoride trucks.  It says with auto ride to run no ring, I wonder If I take the ring out how much more it will drop?  I kinda wanted to put an 8mm ring in place of the 10mm in on the right side to make up for the 3/8'' lean though.
I'm right at 5" in the front with no rings on the left and an 8mm ring on the right to compensate for the lean.
Edited by dla
Has anyone used the IHC kits? Came across them and they look well put together.
Sent from my SAMSUNG-SM-N920A using Tapatalk
They seem like a djm replica and their helper bags are a replica of mcg. I personally will never use a djm product again so I'm against IHC kits
I was looking at their 4/6 kit which is $760 shipped. If I needed helper bag I would definitely go with mcg.
So I've been doing more thinking and research, and I think I want to wait to do a 3/5. Living in Wyoming I don't want to do to much and have to pull it off and go higher. What I was thinking on doing is moving the mounting of the strut from the top of the control arm to the bottom. I've seen some kits that use this as an option with a 1/4" spacer. This will be easily reversible.
For the rear I was thinking about removing the spacer in the leafs. Again easily reversible and if I do want to go lower, I'll need to do this anyways. If I like the look or think about going lower I can save up and get a kit with shocks and struts. I'm about due for new shocks and struts having 130k miles. Any input would be appreciated. Thanks!
Do not flip the strut.
I'm having a very hard time deciding on what kit/how many inches to drop 2016 Silverado regular cab with stamped steel control arms. I think I want 4/6, seen Mcgaughys offers a kit I like. Now my question is buy the kit with the shocks (not sure if they're any good) or buy a kit without shocks and buy my own shocks?
4/6 looks killer on these trucks. The mcgaughys kit is really good stuff, though I can't speak for the shocks. 77f22961f67c154135dbeaf4eaad1d71.jpg
That truck looks good! What shocks did you use?
Mcg
Thank you! My truck is a 4x4 so I had to do it a little different than most guys with 2wd trucks. I have 2" spindles with stock shocks and 2" lowering springs up front, and a flip kit in the rear set at 5 in that pic but next week I'll be bringing the rear to 6".
I have the Belltech shocks and they ride great
On 4/14/2018 at 6:52 AM, qwank said:
I guess it's all in my head, It seems to be the same.  I made sure to tilt the camera up this time so it didn't look like I was going uphill.
trucksun.thumb.JPG.40e8ac7c69c6eb62f13ee7cc5cfde783.JPGtrucck2.thumb.jpg.3dc0386046a59e20456a3b8adc1dd58c.jpg
Can you get me a quick picture.  I need to see the distance between your frame and axle pad in the rear. If you can hold a tape .measure in there that would be even better
I'm actually under the truck today, I'll get you a pic of mine in a bit if it'll help. Flip kit set at 6"
Yes and is it a rc or cc?
    RichardRS
    RichardRS
  • Who's Online   4 Members, 0 Anonymous, 806 Guests (See full list)
    • Howdy folks,   Recently I pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain (part numbers coming soon - will have to disassemble), and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash for the heating element.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But I seemingly can’t turn it off AND still no backlights on any of the buttons.    Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • I'm about 1800 miles into my last oil change, and yesterday a message appeared saying oil life was at 77%. Not sure why it popped up but I think all of these electronics could be susceptible to solar flares or somesuch. I change my oil right at 3K each time, and that was the first time in 10870 miles that message came up. Strange thing is that it showed on the screen at all since I don't drive with that sort of info displayed on the DIC.
    • I’m praying that someone sees this and can help me out… pulled a heated steering wheel and clock spring out of a 2015 Sierra All Terrain, and just installed it on my 2016 Sierra WT (as base model as it gets).   On install, I noticed that I’m missing the connector often tucked behind the dash.     No problem… or so I thought.   I used an “Add-A-Fuse” at my heated steering wheel fuse location, which has voltage, but no wires. I ran it to the positive of the heated steering wheel (Violet/White), and took black to ground.   Hooked up the battery, turned the truck on - no heated steering wheel. No button backlights. Was pleased to see that my cruise control was working though.   Read a post suggesting reversing polarity, so I gave it a shot. Violet and White to ground, Black to power.    Aha! Heat! But can’t turn it off AND still no backlights.   Checked all fuses, everything is still in good order. I’m stumped.   Does anyone have any insight? If so, please share!
    • Checked the pads today and there's plenty of meat on them. If the message keeps coming up, I'll just answer YES that the pads were replaced and wait for the squeal.
    • Welcome to the Forum! Always post the code definitions along with the codes. there are over 18000 possible codes, no one remembers them all and most will skip over your post rather than look them up
