well that sucks
I got the impression they were focused on their dealer package business, putting together trucks for dealers to sell, and weren't all that interested in retail to the general public. I hope that's changed. But it kinda turned me off of their stuff.
finally got my belltech front struts/shocks part# 25004, will be replacing my stock ones with these this weekend, and hopefully it will get rid of the clunking sound coming from the drivers side front, that im getting everytime i go over a little bump in the road, its getting louder and sounds worse.  any thoughts on what the noise could be?  anybody????.......
I started getting that recently.  I'm going to swap out the struts for my coilovers smd hopefully that does the trick
what kind of drop did you do?
what kind of lowering kit did you use?
coilovers from where?
or are they adjustable struts?
Mcg adjustable kit. I'm 4.5/7.   I got viking coilovers with atomic fab mounts
I think I'm going to install a transmission (transfercase in my truck) spacer.  The angle of the drive shaft at the transfer case is too much IMO.  The spacer Belltech gives you is for a 2wd.  They want you to use some sleeves for a 4wd but  I don't like that setup.  I'll probably make my own copying the 2wd one but making it longer to fit the transfercase.
Edited by qwank
1527365087272.jpg.b6b2bf2932d42acbf289203065a50a63.jpg1527472242080.jpg.ff8dedd5de32c2f87ef56292d8da20d7.jpg14 Z71 4x4 Lowered on 3/5 Maxtrac kit.  Wheels are 24x10 oe reps wrapped in 305x35 24.  Had to trim fender liner, and rubs slightly on big bumps, otherwise runs great.
what was used to lower the front, struts, springs, or both?
I'm pretty sure maxtrac is spindle and coil spring
I'm just wondering if anyone has paired a coilover with djm 4" control arms ?? Wanting to go another inch down in the front ,but I want to do some ride improvement at the same time. Didn't have a good experience with the drop struts that are out there.
I'll let you know in the next week or 2 how my viking coilovers ride when I install them. As for thr arms. I hate them. I had them on my truck for 30 minutes and immediately pulled them off for spindle and strut
Yup, spindle and drop springs up front,  flip kit and shocks in the rear.
And it doesn't even squat when hauling that entire cooling tower!
  • Haha 1
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 452 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
