25 minutes ago, Dr Awesome said:
And it doesn't even squat when hauling that entire cooling tower!
I've never even looked at it like that. Ha Ha.
Anyone lower then 2/5 on stock size tires without getting a bunch of rubbing?
Im considering adding spindles and going to 3/6 or 4/6 but im running 285/45/22 on 22x9.5 +24mm wheels, and i would rather stay at my current drop then go to a smaller tire.
My current drop is 2/5 (Belltech shocks/flip kit) right now and have no rubbing, but its definitely close to the fender liner on the front..
also anyone having issues with 4x4 on a 4/6 drop, that needs to work with our winters here! haha
I'm at 4/6 with 305/40/22s and I do rub a bit, but it doesn't rub so bad that it bothers me, just light contact on the liner. Also my 4x4 works just fine.
Sent from my SM-N950U using Tapatalk
same here.  except I'm on 285/45R22s
The only time I get slight rubbing is hard left backing out of my driveway, which goes up a very slight hill on the way out.
Edited by qwank
Only left its becsuse you have the Chevy lean. Lift the drivers side half inch to even it out
my truck does not lean any more.  I have a 10mm ring on the left side strut and no rings on the right side and it's exactly level on both sides.  I've just never taken a right out of my driveway with it yet
Good to hear thanks guys, might have to get a set of spindles and get her sitting a little lower! I know they say they clear 17’s but anyone put some 17’s on after spindles to confirm? My winter wheels/tires are 17’s.
Not sure on your 4X but my Belltech spindles worked with my stock 17's. they supply a thinner nut for the lower ball joint stud that needs to be trimmed.
Edited by dla
16.5 and up have the add arms. They are thicker.
It all depends what arms you have
Cast aluminum/stamped steel
my truck came with aluminum but I actually had one replaced on warranty due to a clunk in the front end and they replace it with a stamped steel one so apparently they are interchangeable.
Anyway I would be looking at Belltech 2514’s.
That thin ball joint but is almost scary small!
You can fit a 17 with a small spacer   i dont think you can fit one directly on though
I wish they gave you that little nut for the upper ball joint
I dont see why you couldnt tske the nut to a hardware store and find one.
Probably, but that would require effort lol
    whenindoubtuseahammer
  • Who's Online   2 Members, 0 Anonymous, 350 Guests (See full list)
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
