16 minutes ago, CajunFries said:
Hi guys! New to the forum here. Just picked up a 2018 Silverado Crew cab standard bed few weeks ago. Looking to do a 4/6 drop with DJM kit. I’ll be using it to haul my bikes to the track. I want to get a helper bags for it but can’t really find a solid answer on what brand and model I should go with. I see some people run the McGaughy’s helper bags but I don’t see one for 2014+ models. I also saw air lift got a kit out (model 59209) but I did some research on it and people are saying it doesn’t fit The truck. Even though the site said it does. So if anyone can give me a pointer on what brand and model I need I woulda really appreciated.
Also is there anyone out there running DJM 4/6 kit on their crew cab and standard bed? Does the axle hit the frame often even without any load in the back ?
Dont do djm. Secondly for the bags. I use to have the mcg bags. Bolt in no drilling
What’s wrong with DJM kit? And what brand should I be looking into?
Balljoints go to shit quick and the ride
You need a spindle and a strut
Just this year not even including my truck I've switched 7 trucks from djm to mcg stuff
Truck picked up last night and lowering parts ordered today!  2018 Chev RCSB black out edition - 5.3 2WD w/ 3.42's
Anyone else running the McG 7" flip kit? Part # 34147
I have the mcg flip on my 16
Another question, the 2514 Belltech 2" spindles. Those will work with both cast spindles & steel arms as well as the trucks that came with the aluminum spindles & arms correct?
Most of Belltech's site states anything 16.5-18 take those 2514 spindles.
Aluminum and stamped use the same. Cast uses different
You're talking about the arms. What about the spindle?
Thats what im saying. Aluminum and stamped steel use the same lowering spindle. Cast uses a differant one
To clarify, aluminum and stamped steel control arms use the same balljoints, so they can use the same spindle. Cast steel control arms use a different balljoint, so they need a different spindle.
Sent from my SM-N950U using Tapatalk
Check DJM website. They explained it very well. I had the same questions when I was still looking for the correct parts and what not.
Mine is a 2017 Silverado RCSB, I then checked my Spindle to make sure. DJM site mentioned about two types of spindle. A Cast Aluminum and a Cast Iron. The picture at DJM site helped me in making sure what is my stock spindle. It is a Cast Aluminium(as what djm site mentioned about 2016/2017 models).
Belltech mentioned about #2514 that fits to a Cast Aluminum spindle. So I made the decision and yes it fits perfectly.(I think all Of these are because of the Ball joint fittings,maybe)
Just check if yours are Cast Aluminum(which I believe they are), you should be all good.
Perfect, that's what I figured but couldn't find the exact info. Thanks!
I have steel arms and cast iron spindle. My brother's 16" Sierra 2WD RCSB is the same.
Edited by Dinner
Then it might not fit. Check with Belltech to be sure.
I'm calling tomorrow to be sure.
From my understanding from their site and a few others is every 16.5-18 is as follows
4WD - Alum spindles & steel arms
2WD - Iron spindles & steel arms
Someone correct me if I've got that wrong...
Edited by Dinner
    whenindoubtuseahammer
  • Who's Online   1 Member, 0 Anonymous, 364 Guests (See full list)
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
    • In the 80's 90's I'd run Honda's 7,500 miles between changes using Red Line HP 5W20 and do it for hundreds of thousands of miles with issues. Back in the day it was an SAE 20 with the HTHS of a SAE 30 and SN add load. It was also very polar. Oxidation VOA was over 120. Besides those motors were SPFI and lean burn tech. I could have likely run it longer but never did.    We had a Toyota bought new I ran on Pennzoil's latest and greatest synthetic of the day with "Penthane". A made up word for a very low dose of PAO. Tried 7,500 mile OCI's in that Group III/VI chemistry and the rings tapped out at 90K. Rocker box wasn't as bad as the one Punch put up but it wasn't good either. Also a SPFI motor.    I'm around 3,750 across the board on these GDI monsters and the oil it tapped out by then usually on TBN/TAN crossover and color. Red Line HP Euro.    The AMSOIL SS brochures tell you to follow the OEM values for the service class but that it can be run up to 25K if monitored. I can't imagine what motor could go that distance and not tap out. I've never owned one.    Yes, I know. Lot's of people do. I'm just not going to be one of them.
    • I knew a guy in the early 80's that bought a new Monte Carlo and ran it a 100,000 miles without ever changing the filter or the oil. Just kept adding. It looked like that inside.
    • Good evening. I was lucky enough to get passed down to me a 2007 GMC LBZ that was my great uncle's. While the underside and rockers are more or less gone I feel like with time I can restore it to working order since it only has 110,000 miles and he put nearly every option he could get without getting the new body style since he did not trust DEF. So far I have done everything I can think of but when I put the key into the ignition nothing happens. I put 2 brand new batteries in it. Cleaned the terminals. Check all the fuses and relays and they all pass with my multimeter. I know I'm missing something that I just cant think of. The only odd thing is the OBD2 port works which makes me think its not the mega fuse. Any advice would be greatly appreciated.
