12 minutes ago, UofAZCats said:
Picked up the truck today.  It is still missing the reverse hanger which will allow the rear drop to be raised but the shop needed me to pick it up because they close on Friday for a week due to vacation.  The part is due to arrive on Friday and if it does in fact arrive early enough on Friday they will install it before closing for vacation.  Hoping for a little good luck.  I also have ordered 1.5" spacers that hopefully will help with the rubbing I am getting or anything more than a moderate turn.
So far I have 3.5" drop on the front and it does appear that the front end is settling lower since the pictures I posted from the shop last week.  The rear is still a 7" drop.  These pictures make the truck look more level than the previous but the rear is still lower than the front.  Not sure if I am happy with so much drop.  My goal was a small drop of 2" in the front which would have mitigated rubbing and not make the drop so pronounced.  I'll see how everything looks after the rear gets done.
Next is getting new tires.  I held off until this step was complete.  Anyone have recommendations for 22" wheels?
PS - in trying to help Nasty out - Nasty does not endorse this kit or any similar that replaces controls arms.  Hopefully this helps saves some wear and tear on his keyboard.
Haha i hope it works for you but this sunday im scheduled to have yet another local person with inez arms to come over so i can swap them out. I should thank inez for giving me all this side work :)
  • Haha 1
On 7/17/2018 at 3:15 PM, Rally_18 said:
so i have flipped through many pages Does and one have a 4x4 thats leveled by just lowering the back. id like to see pictures
I literally did this the minute I got my truck home. Took the blocks out from under the springs.  It was still slightly higher in the rear, but the regular cabs sit higher than the rest.
Now I'm 4/6 on 22s
Edited by qwank
Now I'm 4/6 on 22s
I dont know if i want to put the lift hanger up to lift to 6 or notch the truck and lower to 7.5-8
go lower first. you can always go back up easy
But then my frame is cut.   Thats my only thing. Do i want to cut this still newish truck yet
you already cut bumpstops and shit off,  what's a little notch?  lol  Frame will probably be stronger when you're done.
Its an underbed notch.   But i had thethem tske their notch and make the notch area smaller. so its beefy as hell but onceyou notch , then you get into tubs and doghouse.  So it would be neverending
  • Haha 1
15 hours ago, jcfountain33 said:
Belltech 6401 includes 2" shackles and spacers which allow you to use your existing U-bolts. On my 2017 Silverado Crew LT, fender to ground measurements are within 1/4" all the way around.
I don't have pics on this phone, will try to find them to post.
Sent from my Pixel using Tapatalk
Yes, there are spacers included in the kit. though that time I was not thinking of re-using the ubolts. One other thing, I also don’t like the longer bolts now be sticking too much out under. 10CAD per piece anyway. Hehe
On 2018-06-17 at 7:33 PM, 204-WPG said:
Maybe these measurements will be more useful to you...from the center of the hub to the lip of the fender....front is 19” and the rear is 20”.
Driver side Front strut is set at 24mm spacers, passenger side at 16mm. With 2 “ drop spindle.
Rear is set at 6” with Street Performance Shocks (2210FF). Too stiff for my liking.
Strange. My rear isset at 7" and im at 17.5 from hub to fender
Just measured from centre of the wheel to fender. I'm all over the place but may try a better piece of ground
DF - 18"         PF 18" 5/8
DR - 18"         PR 17" 1/2
Fuel tank is full, going to find sometime later tonight to remeasure
Front is Belltech 2" spindles and struts with 10mm spacer
Rear is DJM 7" flip kit and Belltech SP shocks
Edited by Dinner
Hmm, I removed the stock hanger, replaced it with the hanger that comes with the flip kit Belltech 6525.
DF - 18"         PF 18" 5/8
DR - 18"         PR 17" 1/2
How’s the ride at the rear? Do you like it? Mine is bearable but I hope I can get a bit more softer. I watched Reklez suspension posts, they prefer to use the Nitro Drop 2 on Regular Cabs.
Mine is solely for daily driving, no towing, so maybe nitro shocks might suit for my taste,
Rides really well so far. I have maybe 200 kms on the new set up, I'm just sitting lower in the rear than the front
Which holes did you use though? You might have it set at 5 because thats what those mesurments look like
    • Just buy the tube and move on with life.
    • Glad that worked, and in this case that is all on Autel for somehow dropping the ball for not updating the GMC section properly.    I believe in the basic section or unless it is in the advanced, when one does a check of lets say individual sensors for what the pressure is ( and it shows a temperature as well ) , I think it picks up on what the model number of the sensor is in a certain section where you choose "OE" sensor or at least mine is telling me what the model number is and matches to what they actually are and that is the number I quoted in a prior post.    I don't recall now if I had said prior that I discovered with my truck anyway that no matter how low I set the placard pressure for the rear tires, if the physical pressure is under 35 psi and I drive it for about 15 miles the pressure warning will come on for one or both rear tires. I am speculating that there is something else in the trucks system that over rides the placard pressure setting once it drops below that minimum pressure to run a metric LT tire at. The weird thing is it does not trigger right away after driving a shorter distance, it took that longer drive for it to trigger. Just something to keep in mind if you were experimenting with pressures below 35 pounds for a tire designed for lower pressures ( larger than stock floatation series tires ) and not being overloaded of course.
    • I've seen a scant few YT vids on them, but it's always in a performance application.
    • No clue. Service advisor said he'd call me this morning, which I'm 99% sure won't happen. They had the truck 5 days, and I didn't hear a peep. Finally had to call them yesterday. I guess they'd be content to just let the truck sit in perpetuity.
    • I had a little bit of time before I left for work this morning, so I plugged the scanner back in, and I selected Chevrolet Silverado instead of GMC Sierra, and the very first option was for a 2026 so I selected that one and I seen at the bottom it had the option for psi change unlike in the 2026 GMC Sierra, I selected that option and it took a little longer than the usual vehicle not supported, and sure enough I got into it, and it let my change the psi values.. I no longer have the low psi warning light!   Thank you for recommending me to try it under Chevrolet instead! I can confirm this device does work for a 2026 GMC Sierra 2500 hd 6.6 diesel  just have to select Chevrolet Silverado instead of GMC Sierra.   Maybe I'll contact Autel and let them know of that issue and maybe they will fix it for the GMC option  because some people probably return the scanner due to it not working under GMC Sierra.
