13 minutes ago, qwank said:
Probably, but that would require effort lol
I need to get my coilovers in.  I'm having the exhaust done this weekend and my new rupes pilisher shows so you know I have to test it out. I'm hoping to get the coilovers in next weekend. Also I'm ordering new wheels in the next month
finally got my drivers side front clunking noise issue fixed, by installing belltech front lowering struts part#25004 and also reinstalling the stock springs and removing the drop springs that came with my CROWN lowering kit.  truck is riding a lot better. the only issue i have now is, that im getting more front end rubbing when wheels at full lock, than before due to the fact that the truck is sitting a little lower than before.  I want the truck sitting level, so now i have to address that problem. either lower the back so more or raise the front a 1/2 inch.  THIS IS BEFORE
was not a blown strut, i was told that the stock strut was to compressed with the lowering springs the came with the kit.
8 hours ago, ozone said:
THIS IS AFTER5b13f274141d4_storageemulated0Androiddatacom_sec.imsservicefilesSamsungMessages20180602_183634_1527979008416.thumb.jpg.e2ee040a0174cf68f5c76554a916f9cd.jpg
Is the belltech strut at the lowest setting? The strut is all you used to lower the front? I ask bc I need to install mine, and am wondering if I should only lower it an inch.
Thanks
Thanks
Yes I only used the lowering strut, it's set at the lowest setting which is 2inches.
I looked through 100+ pages and didn’t find anything on helper bags. Maybe I didn’t look hard enough but does anyone have a 2/4 drop with helper bags? I’m currently leveled with drop shackles but want to do a 2/4 drop.
Mcg bolt in helpers. I have a set I pulled off my truck
Will it work with a 2/4 flip kit? Do you have a part number and how much are you looking to get?
Edited by 2k10CrewCab
On 2018-05-29 at 9:52 AM, Derek66lsx said:
Anyone lower then 2/5 on stock size tires without getting a bunch of rubbing?
Im considering adding spindles and going to 3/6 or 4/6 but im running 285/45/22 on 22x9.5 +24mm wheels, and i would rather stay at my current drop then go to a smaller tire.
My current drop is 2/5 (Belltech shocks/flip kit) right now and have no rubbing, but its definitely close to the fender liner on the front..
also anyone having issues with 4x4 on a 4/6 drop, that needs to work with our winters here! haha
I am currently using 275/55/20 stock tires and rims. Belltech spindles and struts. My struts are set with 2pcs of 8mm spacers (16mm) on the passenger side while the driver’s side at 24mm(or 3pcs of the 8mm spacers). From the lip of the rim, it measures 7.5”. To answer your question, I haven’t experienced any rubbing so far. Or say, with my normal driving, so far no rubbing at all. By the way, I  have a 4x4 rcsb too.
I think I may have a very slight vibration off the start but will be a totally smooth drive after. Is this the “small vibration” that a lowered truck that most of you guys are talking? The Belltech flip kit comes with the transmission spacer, though it says  in the instruction for 2WD only(I’m 4WD) so I am wandering if this is the spacer for that regardless.
I know now some of our guys here uses the same Belltech parts. May I know anyone experiencing the same and did you use the spacer or what.
i am on a 3.5” / 5” set up.
I feel this same vibration that you are experiencing.  I want to put a spacer in, I wish belltech gave you one for the 4x4 that didn't consist of stacked washers.
I sent an email to Belltech just a while ago. Provided them the details. Hope to receive some feedback from them next week. I also brought up the rear shocks 2210FF ride quality in a RCSB. To my taste, I feel that the shocks are a bit stiffer. I asked them for any suggestions/alternative shocks , if they have.
Tbis is normal I think. I've had it the whole time I've had my truck lowered. No matter what just off the start its slight for a second and then it stops
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
