2 minutes ago, Daly said:
Just want to verify before I order, is this good for a 2/5 drop? 2018 Sierra rcsb 4x4. Keep in mind its Canadian pricing.
Sorry to keep asking, just hate spending money twice.
Id go with spindles for just 2" drop.
11 minutes ago, qwank said:
Just buy the spindles too and go 4/6
Or even 3/5.  4/6 isnt even low on these trucks. They came with a factory 12" lift
Edited by Nasty
Does anyone have a part # for 4x4 drop spindles? I'm only going 2/5 for the same reason I only do leveling kits. I like the mostly stock look, just a little difference. And I'm not looking to mess with shortening the driveshaft.
Should I consider shims with a 5" drop in the back?
I just went 7" in the rear with mcgaughys and no shortening anything over here. Took it up to 100mph and no shaking at all.
You might have a slight rake. You may just want 2/4 then. And you wont know if you need shims until after you drop it. And not everyone has to shorten the shaft 6" drop wont need it. Some 7 do
I've already dropped the back with shackles and removing the block and theres still a bit of rake, that's why I'm thinking 2/5.
My truck with a 2/3.5 drop for reference
Edited by qwank
  • Haha 2
Illbe lifting my front up to 4 and with my calculations ill be lifting the rear up half inch or so as well. I vant get myself to notch the truck but im saving it
On 11/9/2018 at 9:03 PM, qwank said:
Mine is at 17.5''. It looks funny because of the angle I have to hold he camera.
your's looks like 5 or 6 in the front, I wish I could get mine that low using what I used.  and I only have one ring on on one side.   The other side has no rings
anyone have a measurement for the rear also my front is 17 1/8 in the front on the pass side and 17 on the drivers side.
I think im 17.5 in the rear with 7" drop. Or close to that
Well, reklez and performance drive line. Guess I just need to find time to start cutting the truck apart. Hope everyone's having a good weekend.
We are all lucky, I was just looking at the NBS '19 kits and a 6'' rear drop requires a frame notch.  And you need 22'' wheels to clear drop spindles.
Because those trucks are homosexual anyway
  • Haha 1
    DroppingDiesel
    DroppingDiesel
  • Who's Online   1 Member, 0 Anonymous, 707 Guests (See full list)
