It aligned after the crash with no problems
I've got 4/6 on a 2016 4x4 rcsb, the alignment is close, but they couldn't get the caster within spec. Truck still drives grest, and I honestly can't tell that anything is off.
Also maxtrac told me my spring was a 1" spring. Definitely a 2" because along with spindles I'm at exactly 4" in the front.21c5f7d98d40ff3d3594d891832f5913.jpg
Sent from my SM-N970U using Tapatalk
You sure you didn't get the 4/6 drop kit? Nice, so your camber is good and you didn't have use a add on camber kit?
Also, what is caster and how does it affect your truck?
There was no kit lower than 2/4 for 4x4 trucks when I lowered mine, so I used mcgaughys spindles and what I was told was a 1" spring. I ended up at 4" up front and liked it.
Camber is how far forward or backwards the "hinge" that your wheels turn left or right leans....I hope that makes sense. And I'm not real sure what effect it has on handling.
Oh thanks for the clarification but I was referring to caster. How does that affect my drive ability?
Doh! I meant caster, not camber. And I've seen no negative effects on my truck so far.
You used no camber kit right?
On 10/27/2020 at 7:09 PM, SirenRed16 said:
What wheels are those? They look killer.
Forgeline Vx-1
On 4/28/2020 at 8:22 PM, HCSilvey said:
17’ 6.2L 4x4. 3.5/6 Max Trac 2” spindles and adjustable struts. Moog 2wd upper and lower A-arms. Flip kit and lift hangers out back. Helper bags for towing. 22” factory RST wheels with stock size tires.
Hey isn't this your truck?
https://www.streettrucksmag.com/lowering-a-17-chevy-silverado-1500/#
Did you have any camber issues with this kit? Hiw much exactly did this lower your front and rear?
52 minutes ago, 15GMCALLTERRIAN said:
2015 gmc slt all terrain 4x4
3/5 IHC KIT WITH HELPER BAGS
Nice truck, could you take a picture of the clearence between the axle and frame?
Also, how much was the kit and installation?
Thanks , kit was about 1160 install was about 900 with alignment
Damn, 900 for installation? Why was it so much?
labor on the rear reverse hanger install ,flip kit, shock install grind the bumpstop and air bag install for rear ,control arm replacement upfront ,tie rod trim and bushing install and alignment, then recalibrate all stabilitrac sensors and compass  . Other than that im not sure . i shopped it too lowest and best service i could find all prices were ball park the same but this kit is one of the best quality and best when it comes to alignment  , for those who know DJM this is like a 4x4 copycat version and the helper bags are a must to keep the towing functionality
Edited by 15GMCALLTERRIAN
    ncleg
    ncleg
  • Who's Online   1 Member, 0 Anonymous, 1,586 Guests (See full list)
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
