GMC compared to Toyota
Its not a priority to me when I buy a vehicle. God forbid.... I just buy what I enjoy.
If I like something I drive it and buy it. If it only gets 13 and the competition gets 15 but I don't like the truck.... I don't buy it. Its simple... really really simple. Diesels are garbage... you want a tractor you buy one lol. I got my fill throughout life already. Well have fun buying your economic sports car.
Sent from the Great White North
  • Replies 77
Ok guys enough
Let's get back on track
Ryan
just for the record. if you look at the ford 6.2L and the gm 5.3L torque curve. the gm 5.3 has more low end torque and the 6.2 doesn't meet or exceed the torque of the 5.3 until the 3-4k mark. I find that quite funny.
I haven't driven the 14 5.3 nor care too.. but I would buy that real world. The Ford 6.2 has no real low end power... like how I felt the 13 and down 6.2 GMs are. The Gm 6.2 has some potential and has some good low end power so it seems. Its no rocket either but its better than the Ford for sure. Fords tranny shifts better... which makes no sense as its the exact same transmission as in the gm trucks lol.
I hate saying this as they should do this but a decent tune in the 6.2 fixing the sloppy shifting and lags on shifting would be good.
The 14 gm was comfy and quiet.... but I liked the f150 in that respect as well. Oh and the Ford.... dead pedal jeez. If you think gm is laggy drive a 6.2 f150... yikes. It does okay once it goes but takes forever to realize you matted it lol.
GM LSx motors (in particular the performance ones like this 6.2) have been notoriously underrated, tuned pig rich from the factory, have timing pulled all over the map, and the trannies have extremely low shift torque settings & have torque management tuned in all over the place particularly at shift points. This is due to a combo of mileage, durability, and safety concerns. Whether its an LS1, 2, 3, A etc. you can expect a MINIMUM of 25 and many cases 30+ rwhp from a tune alone (obviously the bigger displacement & SC'd ones are higher). The 0-60 and 1/4 mile times also will be greatly improved not only from the improved AF ratio and added timing but from the reduced (or in the case of my LS1 GTO and L76 G8 GT completely removed) torque mgmt & firmer/quicker shifts from increasing the shift torque settings.
The LSx motors are and always have been absolute animals from the factory, its just that GM leaves them in a little fragile cage you have to lockpick w/ a tune to truly unleash - that's the best way to describe it. You don't get anywhere near the gains from the coyote 5.0 or Ford's 6.2 from bolt-ons/tune as you would from the LSx platform. Those motors are pretty well peaked from the factory - now the ecoboost is another story entirely and is capable of huge power, but how long the drivetrain will last making that kind of power is anyone's guess.
500-550rwhp was about the limit from the stock 6L80 tranny in the G8's (which I believe is same or similar to the new trucks) so you're pretty well off in that regard.
Simply put, there's no comparing the new 6.2 in the GMC to the 6.2 in the Ford. Ones a world-class modern interpretation of OHC pushrod smallblock V8 and the other is a crude cast iron block (bahabbhahhahaha) POS motor stressed to the max that has a sloppy torque curve and overall harsh characteristics - noisy, peaky, and rough vs. broad, smooth, and powerful.
Have not driven a '14 Tundra but have ridden in a '13 loaded limited Tundra with 11,000 miles. I found the ride harsh on anything except a smooth road. The seating position was awkward and seats not comfortable. Maybe the '14s are improved in these areas but the GMs just fit me better and I like the more modern engines in the GMs. I do hate AFM in any makers vehicle.
Lol. You mean LTX now... I build LS's and I tune them via efilive.... I know how crappy the stock tuning is. Depending on the engine some are worse than others. They actually like to run things lean in a lot of cases via power enrichment delay... then to make sure it won't explode add almost zero spark advance. I don't like the 6L80E.... never have nor never will but am stuck with it whether I bought a GM or a Ford. Purposely bought a TR6060 "V" to avoid the 6L90E. If GM releases an 8 speed as talked about... although delayed and now a 10 speed is being yacked about I may look that way. I'm in no hurry for a new truck.... and honestly I would have to order a GM if I wanted one. Personally I would still rather just an SLE with the 6.2 as I don't like leather whatsoever... probably in 15 I am guessing that will be available.
I wouldn't say the L86 is world class... its alright. Definite improvement over the L9H and L92 though which is a great engine in something light if you swap it.... The Gm engines aren't ohc either... just old pushrod like every other v8 they ever built. Cast iron blocks have their place.... anyone building LS's for big power knows aluminum is useless especially the normal castings. They flex too much under high boost applications.
Mind you Ford has redesign due so they may improve over the current trucks too. Time will tell.
I know the design is still "rudimentary", but they're tried and true and now w/ the added technology of DI and the VVT they've had for a few years plus the big fat flat torque curve they produce I do think in a sense "they're world class". I say that because whether you're looking at a some German bi turbo super finicky nonsense or a ultra high revving italian V8/V10 (although I hear they may be leaning toward FI soon too) the power they make @ the expense and complexity they make it doesn't impress me one bit when you see what GM does w/ their LT1/L86 motor that, unless somethig has changed, will run to 250,000 miles no problem w/ nothing but dino oil changes.
It is true Ford is set to redesign there motor we'll see what comes of it.
Ford is always set to change their motors. They can't find a decent motor to stick with (unlike GM and for the most part RAM). They make motors that are too good to be true. Only motor that is good for the light duty trucks is the 5.0 considering many have reported loosing boost in their ecoboost's
Sent from the side of the road...
What year was it?
While many can and will debate the reliability of Toyota, one thing is definite, you wont lose your ass on a Tacoma if you decide its not the truck for you and sell it or trade it
in.
I agree. I traded in a 2011 Tacoma on my 2014 Silverado. The Chevy salesman couldn't believe the value of the Tacoma until he looked it up.
Got within a few thousand of what I paid for Tacoma when it was new. (Not an inflated trade in either)
Since I bought two vehicles this year I thought it would be interesting to post my experience with each.
2013 4 Runner purchased August put on 4300 miles. No recalls, no detects, no concerns vehicle has not had any problems
2014 Sierra purchase September put on 3600 miles. On delivery small dent in right front fender, repaired by dealer with paintless dent repair( 1 trip to dealer) LED bed light not installed at factory, installed by dealer( 2 trips) Poor FM reception, unresolved( 1 trip to dealer) Broken dip stick, replaced by dealer( 2 trips) Back sliding window not able to open, recall part on order. Dealer over 20 miles away round trip.
The local dealer has been very helpful and I believe is doing everything he can to correct the problems. I purchased the Sierra over a Tundra because I thought I was getting a more updated truck. I am wondering it I made the right decision.
First year, gotta work the wrinkles out
I'm feeling a lot of blind brand loyalty here. Well, this is "GM-Trucks.com" so I guess that's expected. None of these vehicles (or the engines) are garbage like some would lead you to believe. It's different strokes for different folks. Drive them both and make the choice for yourself. That'll get you the least biased feedback.
We aint, well I ain't, saying that GM's are invincible, they definitely have their quirks. Crappy trannies (4L60E's), the 8.6" rear end, the front 8.25" IFS differential, rust over the fenders (more common on older trucks). Basically the only thing that doesn't break on these trucks are the motors lol
My 4l60e is holding fine behind a 6.0. The 60e is a crapshoot
    • FYI, I used sq body headers on my 72 and they were a perfect fit with zero clearance issues with the rods and Z bar for the clutch  I agree with post on worn mount rubber
    • I do most of my yard work before 10. My summer walks are usually at Kroger’s. Inside and yes I’ll do light shopping. Usually by noon you don’t want to be outside from June to September. The mail box is a good walk. I’ll walk there about 3 times before the mail comes. My house has two floors if I feel I need to move I’ll do the stairs. I’ll walk down the lane to our rent house with clippers trimming branches along the driveway. There’s always something to do.
    • There is a sign at my chiropractors office that says, "Don't quit, take a break." Sound advice.    On a 65 degree day (F) I can still work pretty darn hard (I'm 72). On a 85 degree day with a good deal of humidity it takes me three days to do what in took at 65 degree in three hours. If I work to muscle exhaustion (back) it will take me days more to recover. Taking breaks to prevent that is most useful. A lift belt has been very useful in preventing both.    Minister was giving a talk the other night where he was speaking of age and he used a clock to illustrate the human lifespan and it's ability to task. 1 to 45 was the second hand, scurry about. 46 to 70 the minute hand. Slower but...71 and up the hour hand...Hummm....until that talk I felt more like the minute hand. 😭   Then he says, the most useful hand on the clock is the hour hand. Without it you can't tell time. (Hour of the watch). I felt a bit better knowing we over 70 are useful. 🥹
    • I still do oil changes on our 2 vehicles and my motorcycle. I have a robot mower for the yard but can't use it in my backyard because my wonderful dog keeps digging the guide wire up so I have to push mow it. Not much of a walker especially during the summer, just to hot. I will ride my e-bike almost daily which helps to keep my knees and hips loose and helps with my balance. That's my story an I'll stick with it. We have been in the mid to high 90's with a feel like temp of 105 to 109 for the last month with no rain. We finally got some rain which cooled it off but were still stuck with the humdity. I do pace myself and that's why it takes me 2 days to do something that used to take a couple of hours.   Peace
    • @newdude great info, thank you!   So opening the thermal bypass valve early (or all the time) would cause temperature to rise more slowly, but above 194F there would be no difference from normal operation?   It seems like the only practical ways to bring down the peak temperature would be to improve the oil-air heat exchanger in some way or increase fluid capacity?
