MotoMedic, thanks for the excellent write up. Is there a trick to get the wire thru the grommet with out much damage? Also what is the powerpro you speak of? I know it is not the fishing line I use. :)
Thanks again for the work.
My method is pretty DIY! I take a wire coat hanger and cut free the bottom straight piece. After cutting, the tips are sharp. On one end, I tape up about 3" of end of wire parallel to wire hanger. Then push the other sharp end through the grommet. It makes a tiny hole then, as you pull the wire through, it stretches the hole just enough so it'll pass through. Makes a really tight seal, so no silicone needed.
That was a typo... I used a PowerProbe http://www.powerprobe.com/
I remember someone questioning somewhere the power tailgate lock's performance in cold weather. While I can't comment on extreme winter conditions, yesterday morning we had a 'record low' of 21 degrees and the power lock still worked like a champ!
If anyone has specific product/installation questions, PM me. I stay mainly in the 2014 section, so I'll likely miss your post here. Thanks.
Just wanted to thank you for taking a picture of the wires. I installed the tailgate lock tonight and using your photos and description I was able to get to the wires quickly without it I would have been searching for awhile since there are about 10 brown wires with yellow stripes.
Works well thanks again for the write up.
I just ordered one of these from Pop & Lock. They have a 10% discount code on the website that's good through the end of January.
Installed mine today. work like a champ, no more using the key.. :D
Thanks again Moto for the awesome instruction.. ;)
Just an addition to my post above, looking back at it if I needed to install this lock again I would have used the positap connectors versus the splice connectors that came with the kit, the splice connectors did chew up the wire quit a bit.
Otherwise easy peasy.
Good point. I also did not use the included connectors. I went the splice / heat shrink route.
This is an awesome mod....simple, easy, relatively cheap.
I Just wonder how the actuator stands up against the test of time.
Do you think you could add a switch to drop the tailgate from inside the cab? I figure with the soft lower feature already included on these trucks it would be fairly simple.
The power lock kit only moves the locking cylinder.
Remotely opening the tailgate would require a separate servo/cylinder to operate the latching mechanism. I'm sure it could be done but would require significant engineering/testing/etc. (the new 2015 F-150 will have the tailgate remote opening as an option)
is this operating on 12vdc? The instructions say no test light and a device that is computer safe for testing. I have a fluke DVM and just want to be sure of what voltage I should see?
11) Now for the wiring... it's a cluster! The instructions don't help much here. You're looking for a tan w/ yellow stripe & a solid gray wire. With my PowerPro I was eventually able to find the correct two. When you're looking for them, start in the top corner closest to the gas/brake pedals, and look for wires that are ever so slightly thicker than the rest. [pic 008]
12) Feed the tailgate wiring through the parking brake grommet under the carpet. It's tight as hell, so as long as you don't make a big hole in it, it won't leak. [pic 009]
13) Connect the green wire to tan/yellow (looked brown/yellow to me) and the blue wire to solid gray. Test lock/unlock feature.
14) If everything works, you can unplug the longer wire provided & begin snaking it from the front of truck to spare tire area, plug it back in, zip tie wherever, replace all panels, etc... and you're finished.
I saw 12volt DC, I used my back probe to probe the wires that motomedic pointed out in his photos to confirm the wires. 0vdc then hit the key clicker and would see the jump to 12vdc, I set my meter to log the max and it was jumping just above 12vdc.
Received mine yesterday and installed today. All went fine, this was much easier than the 06 having to remove door panels. Finding the correct brown/yellow and grey wire was the worst part as they were on completely different sides with one on top and one on bottom. The person that wrote the Pop&Lock instructions was color blind or has never seen Tan.
Thanks MotoMedic for the write up and pictures as they are so much clearer than what is provided.
..continued....
One last thing!
The key cylinder on tailgate will now function differently!
It is always stays in the vertical position, so...
..turn counter-clockwise then back to 12 to unlock
..turn clockwise then back to 12 to lock.
Installed mine today power unlock/lock works great. I just can't get it to work with the key. Looks like the new cam arm flat part (shoulder stops) is keeping the key from going far enough in either direction by 1/16". Anyone else run into this?
Thanks
    • Yes. You need to check out that thing, and the hub further.
    • Would this be normal or a worn CV Shaft? 51K miles 3.5" lift? Boots are intact and no visible leaks showing. Attached is a the video I took. Thanks     https://youtu.be/ZnW7PPRmjJY?feature=shared
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
