I've searched and found some info but I'm trying to pull the trigger on one today.. It seems Airaid has the only legit looking CAI K&N isn't out yet I'm wondering if I should wait it out for a few months to see what gets released? Is anyone running the Airaid with the 5.3 that can leave some feedback?
Thanks all!
I'm in the same spot as you DJ. Wanting to get a CAI but I'd like to have a couple of options to me. I had an AEM on my last car and really liked it. It was a dry filter so you just had to vacuum it and wash it out - no re-oiling it. But they haven't released anything yet either. I'm thinking another couple of months is when these as well as a couple more options for the exhaust will be made available.
I had a K&N on my 03 Blazer and it really woke it up. Sounded nice to when I got in it. The S&B I have in my cummins works really good to. I know this has all been laid out somewhere on this forum but I can't find any testing or real world response with the Airaid.
I have the Airaid for the 5.3 on my 6.2 truck right now and like it. Power definitely picked up along with intake noise.
Does it fit perfect? Or did you have to modify it at all?
After exchanging several PMs with TJay, I ordered the exact same Air Raid system TJay has on his 6.2. Yes, it is advertised for the 5.3, however, Air Raid folks convinced TJay, not only would it work on the 6.2, but they had no immediate plans to release any system for the 6.2, as this one would work fine. I also have a 6.2 Denali, but I have an appointment to get mine tuned in Charlotte on the 21st.. I wanted to get a CAI installed before the tune, so I opted to go with the "TJay Method." That is installing the Air Raid, 5.3 system on my 6.2.
Only "modification" was I had to use the stock throttle body clamp instead of the one from the kit. Other than that everything fit correctly.
I'm running the AFE 54-32332 dry and I'm happy with it. Now they have the 54-74104, I would have probably gone with that if it was out when I bought mine
http://afepower.com/shop/application_searchnew.php?searchtype=vehicle&diesel=false&truck=false&type=gas&make=Chevrolet+Truck&year=2014&model=Silverado&engine=5.3L&x=60&y=18
Yea, KG, I really like that AFE 54-74104. I wonder if it would also fit the 6.2? As mentioned in a post above I just ordered the Air Raid system which has been verified that it fits the 6.2, but I do like the looks of this AFE system. Of course in another 6 months, I'm sure there will be several options to pick from. Thanks for sharing.
Are you guys going w/ the sealed box or the open style? I would imagine the open air style would make more power but require more cleaning.
Isn't Banks performance also a choice among GM trucks?
I think I'm also going wait and see what else comes out, as it is I already was probably the first guinea pig for Flowmaster's system...
I'm not sure they would fit both. After a year or two when there are options from everyone I will probably try out another brand and find someone to buy mine.
I really like the sound mine gives off when accelerating. They have their rating as far as HP but its minimal, however I did notice better a gas mileage reading.
I don't see why their 5.3 wont fit the 6.2, the Airaid one does. The throttle body opening and airbox along with everything else is the same for the 5.3 and the 6.2 engine. They may not know for sure it will fit.
    • Progress... sort of.   Intake is disassembled, spider is out, fuel lines removed. Used a torch on the stripped screw with the lower intake off, much easier when I've got the intake sitting on my workbench, I made it talk. Walked right out with a pair of vice grips once it was nice and toasty hot.   New parts are piling up on my service cart waiting to be installed. Distributor, temperature sensor, new gaskets, fuel line kit, themostat, water neck.   My new pickle is I don't want to spend $600 on a replacement spider. I'm not sure IT is bad. I'm probably splitting hairs. Or it's $300 to send mine away and another 3 weeks of the truck just sitting. I have half a mind to assemble everything with the old spider to see if I can get away with just replacing the fuel pressure regulator to be safe. The obvious issue was the gushing high pressure fuel line which will be replaced. Getting to the spider really isn't that hard, and now I know what I'm doing , swapping it would be a breeze should it absolutely need one. Stupid, or smart?   The part that gives me pause is replacing the distributor. Well, it's already out. And I didn't mark it, whoopsie! Engine was at TDC when I removed it, I know that, so upon correct reinstall the metal tip on the rotor should point to the TDC mark on the distributor because that's where it was pointing on the old distributor. Worst case I'm a tooth off and have to re-stab it.   But then, what? I assume the truck will start. It doesn't appear the timing can be set. Here's the problem: These distributors can't be rotated but a degree or two, by design. What I read is Cam ****** needs to be -2 to +2 degrees, ideally at 0 (and checked/set above 1000 rpm). There should be enough wiggle to get that properly set, but checking the reported value is another potential issue. My Actron 9185 scanner says it supports enhanced GM PIDs and Cam ****** is one of them but it's unclear that I'll be able to correctly see it over OBD 1.5. I can see why people end up junking these things with life left in them. They're an absolute nightmare with tweener-year diagnostics/electronics and unobtanium parts.   Fingers crossed it starts and idles nicely. There can be hope, right? I'ma buy a lottery ticket the same day just in case.   Next steps..DO IT. I have not installed an intake before so I've been reading and watching a lot. Some say NO RTV except on china walls, some say DO RTV on water ports but not fuel/air intake. 1/4 or 3/8 bead on China walls? I think my strategy will be, obviously, RTV china walls with overlap on the gasket corners. Chapstick-style RTV the water ports. Leave intake ports dry. The only set of intake gaskets I could find locally are Edelbrock performance gaskets (uh...for an asthmatic 190hp V6? LOL) so we'll see how they do.   #NoToolLeftBehind. It took an hour, but my recovery mission for my deep 10mm socket was successful. It had rolled down the bellhousing and wedged itself between what I think are the fuel lines? I couldn't see it at all, but with a junk antenna I had laying around, I blindly went poking/sweeping for it, heard it clink, raised the truck, and caught a sliver glimpse of chrome with a flashlight way up there in Narnia. I had pushed it farther along the lines holding it captive, but within access of severely improvised tools, poking and cursing at it to finally knock it free to where I could get a fingertip on it to bring it home.    Not much to see.
    • Thats crazy considering im right next door (Indiana)
    • For a limited time, retail and commercial accounts receive an AMSOIL Vinyl Tool Tray with their order of $500 or more when they use code TRAY726 at checkout. The promotion runs through July 21, 2026.   Order at https://syntheticadvantage.com   Want to use AMSOIL in your business or sell at your store, apply here.  https://www.amsoil.com/business-opportunities/?zo=521390
    • It wouldn’t have happened if the government hadn’t mandated outrageous fuel mileage standards. It does very little for the consumer. It adds cost. Back during Covid there was a chip shortage. They gave a rebate for your truck if it didn’t have the chip to turn on cylinder deactivation. It was 50$ because at best you may see 1/2 a mile increase per gallon. Splitting hairs each fuel mileage trick wasn’t mandated. The government doesn’t do the engineering work and say use this until it’s already in use and they like it. The fuel mileage was mandated. And those add ons the results. There’s a mandate and they are the results.
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
