you got a good deal on airaid . just try to order from jet.com - NO DISCOUNT price is $152.90
. I must have caught the tail end of a promotion then. I'm glad I bought it when I did.
Ok, I installed my cai today and I must say it looks pretty good. The big airbox and filter fill up the space nicely. Now I just have to get used to the sound it makes, it has a weird growl at low rpm/ lots of throttle.
I only have 1,250mi on my truck but there was no oil in my intake or throttle body.0221161404_zpsgkibxstw.jpg
I like this set up. Where did u buy it from? Cost? Thx
Has anyone tried a Spectre brand cold air intake kit 9006. They are normally $149 but on sale for $135. They are aluminum, would plastic be better to not heat up the air coming in to the engine? Any known trouble of check engine lights on after Spectre installation?
I've been lurking but had to sign up to try and get an answer. Is there an airaid MIT that fits a 2016 5.3l? I emailed airaid and just got an auto response that they don't make one yet.
I got the same response:
Hello,
Thank you for choosing Airaid. The 200-985 has not been fit tested on the 2016 model of the silverado so we can not recommend for you to install as we can not confirm that it would work. At this time if you do decide to install it would be done at your own discretion and it would not be covered under our warranty.
Thank you,
AIRAID Customer Service & Tech Support
[email protected]
http://www.airaid.com
Phone: 800-498-6951
The Airaid MIT for the 2015 fits on the 2016. There were no design changes under the hood. I just installed the MIT on my 2016 a few weeks ago.
Hello,
Thank you,
AIRAID Customer Service & Tech [email protected]http://www.airaid.com
Phone: 800-498-6951
I'm not sure what there is to warranty, it's just a plastic tube. But yes, it will fit the 2016 because I just installed it on my truck.
Maybe I should email Airaid and let them know the MIT fits with zero issues...
Edited by Spurly
Thanks, did you keep the stock filter or go with something else?
I kept the stock filter, didn't see a point in spending the money to replace a filter that had 500 miles on it on a brand new truck.
Airaid MIT took all but 15 minutes to install. I noticed the increased sound under acceleration immediately. The glarbal glarbal glarbal under light acceleration took a little getting used to.
I have run K&N in all of my cars and trucks since late 90's. No issues and I clean/oil every 50k miles. For the $40 up-front and then $20-25 every cleaning/oil, well worth it to me. No down-side.
I bought my 6.2L used with a K&N CAI already installed. I don't want to deal with the oiled air filters. Can I just replace it with the dry filter from AEM? Is there a better option?
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
