I am trying to order a console from a dealer, and they are saying that my main part for the console is on national back order.. But I found one for my truck from another dealer but it's for a GMC Sierra , not a silverado... Would it still work... As far as I know the parts for each truck are basically the same but just have different part numbers!! Can any one help me out with this.!!
Silverado part #22995069
Sierra part #22995066
Edited by thrasher2010
Part numbers look the same to me?
Sierra Boy
Sierra part #22995069
Sierra Boy
Hahah yeah I fixed it....
Silverado # 22995069
Sierra # 22995066
Phew...
That makes sense now!... I'm still waiting for my truck to come in.
Sierra Boy
I did not order console parts yet.....Would the 1500 console part numbers listed below, work for a console swap in a 2015 2500HD?
CONSOLE 23466995
PLATE 22995086
PANEL 22817347
PANEL 22817349
BRACKET 22776807
ACCESSORY TRAY 22817343
Edited by crewchief25h
What color is your interior??? I placed an order for all of my parts but it seems that my main console part (22995069) is on national back order, I am thinking that I can order (22995066), boy parts numbers are for black interior but one is for a Denali interior, not sure what the difference is
I would also like to know, also there is a $10 price difference between the Denali and Non Denali Console lol
Hope not much that's the one I had to order
I know on the 07 13 tahoes it is astronomical (or it was when they were new) to buy the console new from gm. They Nickle and dime you on all the small stuff, cupholders pocket pieces etc. Like the guy posted above, he paid that and it isn't even a complete center console
I know right I already have all other parts just need console and plate left.
Anyone have any more numbers for the plates
i don't know why it does not show the lid cover. It's also a Cocoa color console in case someone is wondering; Same part# is $275 online
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
