AgDocktor: looks like there are two screws on top also.Check this thread it might help or the OP might be able to answer your question
3 coil wireless charger install in 2015 Sierra Denali
Edited by 1911-A1
Thanks for that! I really appreciate the link. I will keep you guys posted on my progress.
Sent from my SM-N910V using Tapatalk
Hey guy just got my console in and wanted to say thanks for all the help from the forum. Getting the jump seat out was much harder than I thought but getting the new console put in was much easier than expected. I only used two bolts where the bracket mounts to the dash so that I didnt have to take any of the dash apart and the console is in there solid. I love how much storage room this thing has.
IMG 20160107 153920
IMG 20160107 154055
Nice, I bought all my console parts, just waiting for free time to do the install. Did you get the front three USB'c to charge?
Hey guys I just got my console in, started on it this morning at 9 and I'm wrapping it up at 1:30. Also I have the front 3 USB playing music and charging and I have all 4 cig outlets working and the interior led for the console is wired to my cab lights. Everything went smoothe and I want to thank everyone for the info and insight on the process. I absolutely love this thing. 108199a698f66c4b54c195c18b41d04e.jpg8420513fc28eaa0c4b9cd983d49f2585.jpg0d3bbf23485c65d7b14d688a4bfce04a.jpg
iPhone 6 '14 Silverado
That's awesome Keith!! How did you tap into the lights to get the LED to work? Is that the blue wires in the picture, underneath the console? Also as far as the charging USB's up front: did you use the AC Delco USB male to male connection; one side into the back of the chargers and the other into the HMI?
Hi Guys. I've read till my eyes are crossed so I'll just see if you guys can help. I'm thinking about buying a 2014 GMC Sierra 1500 All Terrain. Currently, it has a fixed center console. However, I have a bunch of kids so I need the flip up console. If I buy this truck, will I be able to buy a jump seat to put it its place? Will it bolt up easily and wire easily? Looks like most people are getting rid of the jump seat in favor of the center console.
Also, anybody on here happen to have a black leather one they need to get rid of?
Thanks so much for any help. Need to buy pretty soon.
For the led light, I took the pigtail and unplugged it from the led. Then I followed the wire down about 4 inches and cut it and taped off the dead ends. From there I took the plug with now bare ends and spliced them and butt connected it to the 2 blue wire you see. One marked negative the other is white it's the positive.
As far as getting everything up front to work I removed the entire jump seat harness from the jump seat. I then plugged the harness back into the floor plugs under the passenger seat. I used all of the connections up front and that's all.
Yes, they should be interchangeable. Where are you located? I have a black leather center jump seat that I will be removing soon and selling.
The pigtail of the console LED?
Edited by nolabell
I'm in SWVA. Close to the VA TN line. Wonder if the color would be the same. Looks jet black to me (leather). Not 100% sure this will be happening, but it might.
I think they are the same, black leather with white stitching. We are pretty far, I am New Orleans, 8-9 hour drive away
Edited by nolabell
Yes the console led I left about 4 or 5 inches of wire on it then plugged it back into the led
Hey what part of Nola you in? I'm in marrero
Wow, I actually work in Algiers and live in Metairie. Small world, might have to summon you for some help with the install lol. Do you have a 2014 or 2015?
    • Hey everyone,   For anyone looking at roof-mounted lighting for the Hummer EV, we wanted to share our M&R Automotive 50" PRO Roof Light Bar for the 2022+ GMC Hummer EV.   The curved 50" bar sits close to the windshield rather than sticking way up above the roofline. The mounting position is designed to keep the setup relatively streamlined while minimizing wind noise and maintaining full use of the factory windshield wipers.   A few details:   50" curved PRO light bar Fits 2022–2026 GMC Hummer EV Spot + driving beam pattern TIR optics White main beam Amber DRL backglow Approximately 15,410 measured lumens through the lens Mounts to factory accessory locations No cutting or drilling required Wiring runs down the A-pillar toward the AUX connections Designed to minimize wind noise Lifetime warranty Off-road use only     The 50" is an interesting middle ground for anyone who wants the visibility and mounting position of a roof bar without stepping all the way up to the larger 60" setup. For the Hummer EV owners here, would you go with the 50" for the lower-profile look or step up to the full 60"?
    • My son got a hatchback withe the aero package for like 17k new. Great little car with amazing MPH
    • Yeah, I've given up years ago with that! I was able to load a few when I first joined the site sometime around '07. Then after maybe 20 pics, it said I exceeded the limit. Now every pic I try to post says I've "exceeded 1mb".   ONE MB??? That's Windows 95 ******, lol!!
    • I get the same results with pictures. Then I figure it out. Then I forget. Screw it.
    • I guess I'm the only one on this forum who can't get effing pics to load here! Do you have to resize them to post, or am I just blocked from uploads?   I have the same luck with automotive electronics ... but this is the ONLY site on the net that I have this problem!   I'd post pics of what I'm working on ... but I CAN'T! 🤬       Just fabbed up the kickdown cable (had to extend the cable mount WAAAY out from the throttle shaft to get a full pull), and parts arrived for the fuel lines on the 940 carb conversion project. Should be able to drive this thing by the end of the day. If not for work, I'd have had this thing done SIX weeks ago.   Got the jetting sorted out last week. Had a real bad tip-in bog that I couldn't seem to correct. Friggin float height was over 11mm too HIGH! eBay purchase, so no wonder everything is screwed up right out of the box! I ended up with a larger dual-squirt accelerator pump jet anyway instead of the single. Also moved the 70 primary idle jet (4 sizes too big out of the box) to the secondary idle circuit, and installed a 57 in the primary. Runs great on the fuel bottle!    Still using the computer for ignition. Going to drive it first and see if I want to go through the project of installing an intermediate shaft with a distributor drive gear, so I can install a block-mounted distributor and run points, 100% computer free. I should do that anyway just from a simplicity / reliability / tunability standpoint. The electronics left me stranded last year a couple times! I can't tweak the timing to my liking right now because of the computer. Tried twisting the cam-driven distributor already ... and the damned thing just reverts back to where it was! That's infuriating. But if it runs well enough I might save that for next season.   Just driving it in and out of the shop to work on other projects, it feels 1,000% more responsive with the carburetor. Also fires MUCH faster when cranking. Can't wait to drive it and see if I got more than 114 ponies, lolol.   Hopefully these don't go 404 like the last post ... https://postimg.cc/gallery/MjhrmZS   Seems like that site went back to dial-up internet! Maybe they'll fix that some day ...
