Those look to be all roof consoles not floor consoles. Or maybe I'm reading the descriptions wrong? I'd be willing to make a drive to one of those areas for a floor console at that price!!
I thought the same thing however if you go to the menu there is a separate category for "roof console". Also note that the color is listed as black on many of those and as far as I know the roof consoles do not come in black.
Looks like it didnt link directly to the option I had selected but if you click "select option" you'll find floor consoles
$346 Shipped is a steal for a complete console!
I have to agree! I was planning to buy a black leather jump seat with the lower storage compartment to replace my standard gray one but for just a few dollars more I was able to get this!
Hi there quick question, going to attempt this swap Saturday. For the double cab, do you need to remove any seats or can you muscle the jump seat out and place new center in. (Any tips would be appreciated?
i was wondering the same thing....anyone sucessfully do the swap in a double cab without removing the passenger seat?
Nobody hit the $300.00 buy it now and as of this posting the bid has gone up to $510.00 plus shipping! :crazy:
You need to lossen the 2 rear bolts on the passenger seat to wedge it up to be able to disconnect the connector for the center console, but the passenger seat does not have to be removed, and the jump seat can be removed with the driver and peassenger seats intact.
thanks!
thats crazy!
marv, did you end up getting one?
im doing a center console swap today and will have available a black leather jump seat w/white stitching if anyone is interested...truck has less than 1000 miles....brandy new :)
I have a new z71 with the 40/20/40 leather. I miss the console I had in my last truck, but I'm not ready to install the console in the Z71.
Does GM make any sort of storage caddie that goes on the floor in front of the seats?
ive looked around, but couldnt find anything that i thought would look ok in the truck.,.....there are a couple options that i found but look horrible IMO....i sucked it uo and bought the center console and plan on installing today
That's awesome. Post before and after pics! Let us know how the installation went!
    • https://www.msn.com/en-us/autos/general/what-makes-this-1963-ford-falcon-red-rocket-special/vi-AA2asoRz?ocid=winp2fptaskbarhover&cvid=be9c1b4f79ff4211c526abd60f6da012&ei=16
    • True. My statement needs qualification. "For a shade tree mechanic, re-assembling the front engine to achieve a rough baseline timing of 0 degrees, as is approximated and indicated by common visual indicator mark alignment, measured with a human eye capable of 20/20 vision *with correction, I am reasonably confident that I have followed the outlined procedures/ prescribed methods for verifying baseline timing."   😉   In the end, the computer sets the timing, it's continuously variable based on sensor input, and the distributor only has a degree or two of physical adjustability intended for dialing in the final setting for cam ****** once everything is back together. But even that final value is acceptable within, I believe, +/- 3 degrees.   I thought my exhaust project was going to be a bear. To my surprise, the old clamps came right off last night, and I was able to unbolt all the hangers instead of having to muscle the rubber mounts. The old cat is ready to slip off the factory y-pipe. The rest is ready to come out with one or two cuts, and I've got a fresh blade waiting. I love living where rust isn't a thing.
    • I work at a Chevrolet dealership & hear it all believe me.  Just reads like there's going to be a fist fight over filters.  Can't get enough, continue!!
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
