Where are you at? Sounds like East Texas. If that's so, come on by, we will figure it out somehow!!
Tampa Florida. The last couple weeks have been terrible if you have to work outside. I typically am able to handle it but will be glad when it's over this year.
This forum has helped me a lot with my center console install.. However I have a problem with the cig lighters that are located in the top plate. The original cig lighter works, but the one I jumped power and ground to does not?? I used T Taps to bridge the power and ground.. Any suggestions is appreciated.
This is the forward most 12v plug coming out of the dash. This plug is 12v (hot) all the time. It was next to the ashtray and 110 outlet. This is where I spliced in the 2nd 12v plug to power the 2 forward most outlets in the new console top plate.
I tied in the new consoles 2 rearward 12v outlets to the original jump seat harness. I was a little surprised being that i have owned this truck almost 2 years now and had no idea that the jump seat 12v outlets were ignition controlled.
if your sure on your connections, I would start checking fuses. will have one for the front plugs and one for the rear plugs
  • Thanks 1
My only real question is, can this brown mini usb be used for anything. Its the one that behind the radio faceplate.
Is that the back of the radio? Or behind the trim ring? How do you get the trim off?
Ok due to the above pic we may be on to something here. That brown USB female behind the radio should be able to be used for the new console USBs. If i remeber correctly their is a cable inside the jumpseat wire harness i cut out that may be able to work. I have to check when i get home from work. Worst case you can order a brown male ended usb and retain the glove box usb also
That pic is whats behind the screen for the radio.
Here's a good video of how to get there. I personally started at the bottom.
Added the chrome handle to mine.
The right side trim panel for mine is on national backorder with no ETA from GM.
Which trim panel are you talking about? I might have one laying around
  • 3 weeks later...
    whenindoubtuseahammer
  • Who's Online   3 Members, 0 Anonymous, 320 Guests (See full list)
    • Enjoy the new truck, it’s a beauty. I’m glad you’re keeping the OBS, I love those old trucks.
    • With large equipment or deep mud it is more of a use the higher gear to avoid spinning tires, getting stuck because of spinning tires and doing damage to your machine. The idea is if you run out of torque before you spin tires you can still downshift for more torque. If you are just spinning your tires in the lowest available gear you are stuck and things break.   Automatic transmissions, traction control and electronic transfer cases change the calculation a little as you the driver have less control over each piece.
    • are there any codes? with lots of rust, perhaps disconnect/clean both sides of the connection/examine cable ends (the wires) for corrosion going into the sheath & replace if necessary/reconnect ALL the power AND ground cables between the battery, engine, frame, cab, fuse box and starter charm.li (website) has a no-start diagnostic procedure you can work through to get it working.
    • Its no wonder you've gravitated to the oil types and brands you have in later years after trying certain brands and one being a specialty oil or at least very hard to come by up here and the other would have been a commonly found oil of the era and the vastly different outcomes as a result to using the vehicles in question the same distance for an OCI . It shows what marketing hype can do without actually having the product to back up the claims and that is no different now with the insane claims that are written on the side of a bottle of oil from some of the off the shelf oils.    What has surprised me and I was already finding this out before I bought my truck with the GDI engine, that this newer fancy technology that seemingly would suggest better fuel economy/emissions with this high pressure spray of fuel is not in reality kind at all to the engine or at least the oils life. Yet they insist on claiming long OCI with this technology just like they did with the port or similar type fuel injection systems when in reality its a step back in oil life to have a GDI system.    I think the mistake your making Grumpy is that your not sending your samples to Blackstone and getting the feel good glowing report that you can run it another 1000 or more miles and then send another sample where they say run it yet another 1000 miles and on and on it goes until your sending in something that looks a lot like road tar and then they may suggest you change your oil within the next 1000 miles 😆
    • I am guessing that engines of that design back then had a better ability to be abused and survive longer than a new design engine with the long timing chain and the overhead cams and phasers etc. But I would never guess that an engine could go that far and not fail spectacularly or at least die a slow death.
