does 2018 fit 2016 silverado?
Physically, yes.
Does anyone have the parts list for the cocoa interior? Interested in this as well
This is a parts list for the dark Ash interior in my 2017 z71 lt. I think the website I used is a little bit more expensive so I’ll have to shop around, just wanted to get a quote from a different place.
On 3/16/2018 at 1:23 PM, b-garage said:
I still emailed gmpartsnow back asking for some sort of confirmation that the console part # does come with the lid and back cover, but nothing back just yet.
So what is the updated parts list ?  I'm doing a swap for my buddy but you said some parts aren't needed?
The question was whether 84288040 actually comes with the updated  wireless charging armrest lid and the back cover. GMPartsnow says it does.
This is the quote I received from GMPartsnow that I posted on the previous page of this thread. This is what I ordered last week. Suppose to be here Monday 3/26. I will let everyone know what shows up after I receive it.
Regards,
big rog (b-garage)
Jim from GMPartsnow responded with a quote:
Order Content
Part Number
Make
Part Name
List
Price
Quantity
Total
84193710
GM
Harness
$35.87
$23.93
$23.93
84288040
GM
Console
$571.33
$387.36
$387.36
22776807
GM
Console Assembly Front Bracket
$22.10
$16.58
$16.58
23467516
GM
Side Trim
$35.73
$25.08
$25.08
22817347
GM
Side Trim
$77.43
$52.50
$52.50
84092080
GM
Upper Trim Panel
$214.28
$145.28
$145.28
11609982
GM
Fender Liner Bolt
$4.57
$3.26
2
$6.52
Subtotal Amount:
$657.25
Edited by b-garage
Alright guys so I've done tons of digging and I apologize. But all I am seeing is people discussing for the newer year silverado's. I have a 2014. How exactly do you go about getting the exact part list to do the center console swap?
Find a truck with the exact color console and options(such as wireless charging) and get the Vin number. Call or email a gm parts supplier( I used GmPartsNow) and give them that Vin and tell them you need a complete list of everything needed. They should email you with a list and a link.
FYI I used gm parts now and used promo code “quote10” at checkout and got 10 percent off my order. It’s. It a whole lot, but it payed for shipping and then some.
Awesome thank you. Looks like I will have to go looking at some trucks at dealerships to find the console and same trim that I have. Thanks!
I used auto trader and found one online while at work(don’t tell my boss)  saved me a bunch of time and a trip to the dealer.
I actually just did the same. I found a 2017 same trim which is reverse tartan. Only difference is it has leather seats and mine is cloth. Now this may be a dumb question. Does it matter if it is a 2017 or do I need to specifically find a 2014?
I don’t think it matters. It’s actually better because you get wireless charging. But I would maybe check out the first few pages and re read that. Or maybe @pgamboa can chime in. He’s gotta build you a custom wiring harness anyways so he may know better.
Any console from 2014 to 2018 will fit your truck.
I have a 2018 Rally 2 and I'd like to install the console. While looking at similar trucks for part numbers I noticed that some of the trucks have 4 port covers for the 110v, USB, etc. and others only have 3 covers. How do I tell which setup would be compatible with my truck?
I just did the same and requested a quote.  I'll post it here once I get it back.  (secretly hoping the price has gone down)
Edited by BluEyeItln
On 3/19/2018 at 9:38 AM, b-garage said:
I finally got an email confirmation from Jim at GMPartsnow that the console assembly 84288040 does come with the arm rest lid and back cover.  So I ordered everything today.  Will let you know if they were right when it gets here for sure.
Here is what came with my order...
IMG_3862.JPGAlso rec'd the side plates, bolts, bracket and cables, just not in the pics.
Edited by b-garage
    • https://www.msn.com/en-us/autos/general/what-makes-this-1963-ford-falcon-red-rocket-special/vi-AA2asoRz?ocid=winp2fptaskbarhover&cvid=be9c1b4f79ff4211c526abd60f6da012&ei=16
    • True. My statement needs qualification. "For a shade tree mechanic, re-assembling the front engine to achieve a rough baseline timing of 0 degrees, as is approximated and indicated by common visual indicator mark alignment, measured with a human eye capable of 20/20 vision *with correction, I am reasonably confident that I have followed the outlined procedures/ prescribed methods for verifying baseline timing."   😉   In the end, the computer sets the timing, it's continuously variable based on sensor input, and the distributor only has a degree or two of physical adjustability intended for dialing in the final setting for cam ****** once everything is back together. But even that final value is acceptable within, I believe, +/- 3 degrees.   I thought my exhaust project was going to be a bear. To my surprise, the old clamps came right off last night, and I was able to unbolt all the hangers instead of having to muscle the rubber mounts. The old cat is ready to slip off the factory y-pipe. The rest is ready to come out with one or two cuts, and I've got a fresh blade waiting. I love living where rust isn't a thing.
    • I work at a Chevrolet dealership & hear it all believe me.  Just reads like there's going to be a fist fight over filters.  Can't get enough, continue!!
    • I just can't think of the exact term GM uses for that higher gvw package without looking at the website but basically sort of a trailering package and I imagine it may also have been created to skirt around the licensing fee differences between a3/4 and 1 ton that apply in some states although ironically I believe in some states its the reverse that a 1 ton is the cheaper truck to license over a 3/4 ton. It makes no difference here in Alberta but oddly enough a 1 ton through my insurance company is a bit cheaper to insure over a 3/4 ton as its based on the insurance statistics they generate.    For sure when ever you do have the chance to weigh your truck and to be fair, try to have the fuel tank full or nearly so rather than give yourself a false sense of the truck being lighter by having an almost empty tank.    In my other comment I was mentioning stock sized tires and partly in case someone was reading this and thinking they could lower their pressure down to what your aftermarket tires are able to do with your empty truck as that is a vastly different picture in the leeway you have to play with for running minimum pressures while remaining safe. I will say also that its easy to see from reactions of truck owners that may have been more used to owning a half ton in the past or a car and be it on a forum like this or in person etc that they get so wrapped up in that placard pressure sticker that they can't get their head wrapped around the fact that an HD truck due to how much it can carry can also vary the tire pressures drastically lower than those pressures ( typically more so for the rear axle on stock sized tires ) when empty vs some car that isn't made to carry much so the tire pressures can't be lowered since it needs almost that much pressure just to carry the empty car.    If I ever do find myself in the states with this truck, I will only be too happy to switch it over to the US measuring system as then I will understand all the dash readings. The only thing that is off for me slightly with US measurements is US miles per gallon as I grew up with the Imperial gallon and to this day up here anyway speak in Imperial miles per gallon ( I don't do that on this forum though as that would confuse everyone for no good reason ).
