Theres our missing cable! holy hell!
Is the output on the hub a black connector though? Might need to be black to black?
Maybe but looking at the pictures of the hub here
I would think that grey would fit in the hub. The keying looks the same
HMI Green to Grey (Front USB Hub) Part 19303284
HMI Black to Brown (Inner USB) Part 19303285
and this new cable output of front usb to glove USB Part 23225657
Alterntively would could use use generic Microusb male to USB A Female or a cable like osirus mentioned
https://www.amazon.com/gp/product/B015HKPDAE?pf_rd_p=d1f45e03-8b73-4c9a-9beb-4819111bef9a&pf_rd_r=HJVW9D9NJGNQETAPW9T4
33 minutes ago, Baldhills said:
youre right, and looking at the cable again the part where it exits the gray connector would put in the way of the other plug on the front hub. IDK I have an extenstion cable that im gonna screw with tonight but I also have the green grey on order (got it from jet.com for 20.00) so ill let you know more of what i find on thursday
Edited by zikronix
correction
On 9/8/2018 at 12:46 PM, Osirus said:
I bought a cheap mini USB female to USB female adapter on Amazon for testing. I disconnected my inner USB hub (the one that wasn't working) and used the adapter to connect a USB flash drive directly to the Output of the front hub. It worked.
https://www.amazon.com/gp/product/B00474R7HO/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
(This part wouldn't be used in the final setup, it was just used to verify that connecting a flash drive directly to the Output on the back of the Front console USB hub worked).
So both hubs are connected directly to the HMI. I verified this worked a few weeks ago, but it means the Glove Box port has nowhere to connect to, however with this testing I should be able to connect the Glove Box to the front Hub and have everything working. There isn't a specific part that I can see that would do this, but they're just Mini USB connectors so a generic cable should work, would just need electrical tape or something to keep the connections secure.
This means I should be able to run:
HMI -> Front Console Hub (Green to Grey cable)
HMI -> Inner Console Hub (Black to Brown cable)
Front Console Hub -> Glove Compartment Port (generic Mini USB extension cable) https://www.amazon.com/gp/product/B015HKPDAE?pf_rd_p=d1f45e03-8b73-4c9a-9beb-4819111bef9a&pf_rd_r=HJVW9D9NJGNQETAPW9T4
I just did this. Aux didnt work
Edit: I messed with this and I thought i had a different wiring than what you listed here, but now looking at what I wrote below its the same and it is working can confirm. I also found this cable.
 https://www.amazon.com/ACDelco-42465826-Original-Equipment-Cable/dp/B01K8C5Q8K/
Edited by zikronix
Looks the same, just doesn’t have the 90 degree bend on connector at glove box. Not sure if it’s needed.  Depends on how much room is behind glove box.
7 hours ago, Osirus said:
Is that female end the same connector that the glove box port uses?
Still criminal pricing, though. :(
yea its nonsense...ill stick with the extension cable. im still not convinced this is the actual part number. Im gonna investigate further
3 hours ago, Baldhills said:
Hmm. That looks promising. Cheaper too.
HOLY SHIT look what I found!  Its a short version, which makes me wonder about this entire wiring thing.
https://www.amazon.com/ACDelco-22885186-Original-Equipment-Cable/dp/B00B4L2QRY
16.00!!!!
Edited by zikronix
Most of my time (when I’m not building harnesses) is spent fishing for the right cable, harness, connector or pins. Just today, I spent almost 3 hours looking for a couple of connectors. I must have looked 15+ schematics on connectors, keying, options and comparing with USCAR connector specifications. It is really painful.
15 hours ago, Baldhills said:
Too short to run from the front dual hub to the glove box though.
That's what I thought when I saw it, too.
    RyGuy43
    RyGuy43
  • Who's Online   3 Members, 0 Anonymous, 601 Guests (See full list)
