Just wondering - why do people not like the bench seat?  It seems like it has most of the functionality of the console other than the fact that the box isn't as deep, but there's still a locking space under the center seat.  Seems like you're just missing out on an extra seat, plus the ladies like the bench seat.
For starters, put some change in the holder on the lid. Or pens/pencils. Now try to open it up to get something out. Not so good. Or try to put a can of pop in a can cooler in those small cup holders. Better yet try a medium or large cup of coffee or soda from McD's. There may be 3 but they are too small. As for the ladies,  I'm 65  and married so that ain't much of an issue.
  • Haha 1
Yep. When you have the harness out, inspect the existing 6-pin that plugs into the USB Hub.
Pin 6 (power) and pin 4 (ground) is the Splice to power up the other Hub. This, along with a USB cable feed from the HMI is all you should need to get a hub working.
Ok... So what's your schedule like so you can install mine?!? I'm willing to drive up and compensate you for your time!!!!
Sent from my SM-G955U using Tapatalk
PM me.
Hi all,  I'm wondering if someone can help me.  I am looking at a new 2017 or 2018 truck, but would like the front bench seat.  Most inventory I see has front buckets.  I know I would need the jump seat, but what other dash pieces would I need to make this work?
I did this swap on a 2002 and it wasn't difficult.  These newer trucks have more electronics and I'm not sure what all I would need.
Thanks.
Thanks.
I've done this swap 3 times now. Besides the actual jump seat, you'll need:
- The front half of the floor carpet
- Dash compartment 23177893 (that number is for cocoa)
- 3 screws that hold the dash compartment 11609456
- Trim pieces to cover the metal brace under the dash 22817747 & 22817748
- Lower insulator 20944557
- 110 volt outlet can be taken out of the console and used in the dash compartment.
Also, you'll have to remove the wiring from the console and do some splicing and connecting to the jump seat.
Thanks.
Ill have a jump seat for sale soon so keep an eye out, and depending on when you get your truck might be able to work out a trade for some parts.
Hi guys , I'm new here went threu the whole 90 pages got excited about swapping a console in my 2016 w/t , did some investigation and i din't think i have a hmi? box all i have is this rite behind the radio face plate , can i change it out to get more mini usb ports , by the way i don't have a usb i the glove box .the blue and black  plugs  on right are mini ports for the usb in bench console , Maybe pgamboa can assist me ,
Edited by frankinbus
If I recall, in mine, the Blue USB port (from the HMI) went to the back of the radio. I’m presuming you are just needing to get USB charging from the USB ports of the console?
Yes , I think the blue goes to radio and the black one goes up yo the jump seat arm rest , I'm wondering if i could get a new radio head and change this one out so i could have one in glove box that reads too . i go to the dealers around here and get a no , no reason , but from what i read you seam to be pretty smart in this stuff.
I don’t know much about swapping out units without some sort of programming. I know that HMIs need programming, but again, not 100% on that. Is your console a 14/15 console or 16/17? One way to tell is if the front USB hub is triple or dual USB and if the inside USB has an SD card slot or not.
Yes truck is two door 2016 , W/T , has two slot usb , but realy surprised it doesn't have a usb in glove box ,
I bought the Vais Tech, XM radio adapter to install and wanted to go with the long console and put the interface under dash , I was hoping one of you guys had done this , the console looks two easy to do , but the computa stuff for usb is crazy
If you look at the back of the USB Hub, (for 16/17 hubs), there should be (2) USB Ports and a 6-Pin Connector. The Hubs needs to have a USB and the 6-pin connector in order for it to work. Because it is a hub, it has chip components that require powers. The 6-Pin connector provides the power while the USB provides the data connection. On these Dual USB Hubs, one of those USBs ports on the back is an input and the other is an Output.
Front of console USB Hub. Right side needs a USB Input (from HMI). Left side is an Output (can feed the Inside Compartment USB Hub)
This is the Inside Compartment USB Hub
    • Looks like you have it figured out. Did you run a sensor into the rear diff housing?    What sort of diff temp swings would you see towing or not? I have wondered how hot it can get
    • Dealer just confirmed that GM is "out of AC compressors."  Not sure if all 2019 to 2026 trucks use the same compressor, but a shortage like that is hard to believe.
    • I think we're reaching the end of constant projects/work.   The water pump bolt appears to have self-sealed, as it's not leaking anymore. I'll take it, and, I'm ready should it self-unseal! I was also getting an oil leak at the front oil pan seal and timing cover and came to find a pan bolt on the corner wasn't even finger-tight. Too easy. And, it was. But, it appears tightening it has reduced a leak producing spots on the ground every time I parked, to just a weep, leaving an occasional dot on the cardboard that lives under it while parked. That's acceptable on a 30 year old engine in my book. I do hate leaks, but, replacing the pan seal is quite the job.   The rear washer line is reconnected and the sprayer works, although getting an intermittent washer fluid drip off the bottom. I think it's just residual...the reservoir filled up the channel in the rear floor and drained down into the upside-down spare tire/wheel. So there are residual puddles all over under there, will wait a few days for it to spill out and dry before I go chasing a potential leak.   The door speaker...no dice. Speaker works just fine, it's that channel in the factory amp that's gone bad. Can't win 'em all. And, whomever buys this will probably tear out the factory radio for something more modern anyway.   I put about 110 miles on it yesterday. Put a lot of wind and heat into it with some mountain driving. Still runs great. Near the top of the pass I got off on a gravel side road and put about 10 miles on with 4hi engaged. Works great.   If ya squint, she's mint! God I wish these were still in production. I can see why they're not. They're rudimentary bordering on agricultural. They began life as a pickup truck and then modern society demanded the rear be enclosed for kids and crap. They're still a pickup underneath, and that gives them lots of ride character, sway and bounce and bump steer. They're alive on the road, and, at least for purposes of nostalgia, it makes driving one a lot of fun.   The Check Engine light did come back on the pass, P0134 for the upstream O2 sensor dropping out. Putting heat into the exhaust causes it after about 10-15 seconds of increased load at higher RPM. The downstream sensor is completely mangled (someone clearly had a rough time removing it, but they didn't replace it?) so I'll just put two in it. For what, mostly to cure the CEL, I can tell the cat is damaged. It's not plugged or fractured, but it's not catalyzing. There's some guilt in not fixing it, but at a cost of $500+, the truck just won't get driven much under my watch. I dislike the smell...running the truck in the shop even with both doors open and the overhead fans blasting, I still reek of pre-cat exhaust. Sticks to clothing and everything else.   Window motor (I'm dreading this), and tires, and that should be about it. 50/50 on Starfire Solarus H/T's, or spending $20 more per tire and going with Cooper Discoverer RT's. I like the look of the RT's a lot more, but is it worth it? I've got a really good (just very old) Toyo Open Country XTX on there now and I like it.
    • From what I've seen, they "could" sell the switch but designed the assembly such that the switch can't be readily removed and replaced without removing a plastic locating pin.  Sure appears aimed at forcing the end user to purchase a $900 shifter assembly instead of a $20 switch.  Thankfully I still have some extended warranty left...  this one has had warranty repairs almost every 5K miles from the day I bought it.
