7 minutes ago, rastasquid said:
Yea I saw that, but it looks like its out of a tahoe/suburban since it has the HVAC controls on the back and doesn't have the outlets up front. I figured with the differences in wiring and missing parts its not worth it, since I wanted to just get a pgamboa harness to plug it right in
On Ebay plan to spend at least $700 or more with shipping included. Once in a great while, you will see them here for about 5 or $600 shipped.
3 hours ago, 14tungstenLT said:
keep an eye out on craigslist as well.  Someone found me one i got it for $300 shipped.
Niiiiiice.... Yea, you do see those as well, but VERY rare.
Small Question , I have bin folowibg the forem for the console swap ,
I have a 2016  2 door Sierra w/t  , does any body know if a 15-16 Yukon Suburban Tahoe Center Console will fit
The dash
The dash
I found this thread about 15'/14' compatibility; doesn't seem so.
On the harness thread, someone mentioned a salvage site: www.car-part.com
Hi , To all , I have all the numbers to order a console , Question how do i know im gonna get a charging top lid ,
You typ the numbers in and does not tell you .
Thats awesome , but a gamble ,I should try that all i see on ebay are for surburbans and tarhos ,
On 1/17/2018 at 7:28 PM, scottnaz said:
Just about 350 miles on my 2018 crew cab Silvy, and the console parts arrived this afternoon.  Now I’ve got to read back through this thread for details on the necessary hardware/bolts I’ll need to source locally; plan on making the swap this weekend.  Also plan to follow up with pgamboa about his plug/play wire harness.
By any chance do you have the part numbers?
VIN 3GCUKSEJ9HG145506 can be used to cross reference the console with white stitching, and a satin nickel colored trim.  It’s not the carbon fiber looking silver.
84199890 console assembly
side panels:  22817347, 2367516
front bracket 22776807
2 front bolts 11609982
Upper trim piece I ordered was 84092080, for the Synthesis colored metal with 110v outlet.
12 minutes ago, scottnaz said:
Well, that didn’t last long..... hope someone around here snatched it up
I actually bought my 2nd console from that same seller.  So hopefully, someone here bought it.
    • Looks like you have it figured out. Did you run a sensor into the rear diff housing?    What sort of diff temp swings would you see towing or not? I have wondered how hot it can get
    • Dealer just confirmed that GM is "out of AC compressors."  Not sure if all 2019 to 2026 trucks use the same compressor, but a shortage like that is hard to believe.
    • I think we're reaching the end of constant projects/work.   The water pump bolt appears to have self-sealed, as it's not leaking anymore. I'll take it, and, I'm ready should it self-unseal! I was also getting an oil leak at the front oil pan seal and timing cover and came to find a pan bolt on the corner wasn't even finger-tight. Too easy. And, it was. But, it appears tightening it has reduced a leak producing spots on the ground every time I parked, to just a weep, leaving an occasional dot on the cardboard that lives under it while parked. That's acceptable on a 30 year old engine in my book. I do hate leaks, but, replacing the pan seal is quite the job.   The rear washer line is reconnected and the sprayer works, although getting an intermittent washer fluid drip off the bottom. I think it's just residual...the reservoir filled up the channel in the rear floor and drained down into the upside-down spare tire/wheel. So there are residual puddles all over under there, will wait a few days for it to spill out and dry before I go chasing a potential leak.   The door speaker...no dice. Speaker works just fine, it's that channel in the factory amp that's gone bad. Can't win 'em all. And, whomever buys this will probably tear out the factory radio for something more modern anyway.   I put about 110 miles on it yesterday. Put a lot of wind and heat into it with some mountain driving. Still runs great. Near the top of the pass I got off on a gravel side road and put about 10 miles on with 4hi engaged. Works great.   If ya squint, she's mint! God I wish these were still in production. I can see why they're not. They're rudimentary bordering on agricultural. They began life as a pickup truck and then modern society demanded the rear be enclosed for kids and crap. They're still a pickup underneath, and that gives them lots of ride character, sway and bounce and bump steer. They're alive on the road, and, at least for purposes of nostalgia, it makes driving one a lot of fun.   The Check Engine light did come back on the pass, P0134 for the upstream O2 sensor dropping out. Putting heat into the exhaust causes it after about 10-15 seconds of increased load at higher RPM. The downstream sensor is completely mangled (someone clearly had a rough time removing it, but they didn't replace it?) so I'll just put two in it. For what, mostly to cure the CEL, I can tell the cat is damaged. It's not plugged or fractured, but it's not catalyzing. There's some guilt in not fixing it, but at a cost of $500+, the truck just won't get driven much under my watch. I dislike the smell...running the truck in the shop even with both doors open and the overhead fans blasting, I still reek of pre-cat exhaust. Sticks to clothing and everything else.   Window motor (I'm dreading this), and tires, and that should be about it. 50/50 on Starfire Solarus H/T's, or spending $20 more per tire and going with Cooper Discoverer RT's. I like the look of the RT's a lot more, but is it worth it? I've got a really good (just very old) Toyo Open Country XTX on there now and I like it.
    • From what I've seen, they "could" sell the switch but designed the assembly such that the switch can't be readily removed and replaced without removing a plastic locating pin.  Sure appears aimed at forcing the end user to purchase a $900 shifter assembly instead of a $20 switch.  Thankfully I still have some extended warranty left...  this one has had warranty repairs almost every 5K miles from the day I bought it.
