If I don’t want the wireless charging is their another part number that is cheaper? Or do they all come with it now
I think they all come with it. I'm now investigating the console part number cause the one above doesn't appear to have the white stiching as in my truck. I found a list of part numbers for the center consoles. And I found one that that's jet black and has the GMC product code vs the Chevy. And this might be the difference.
Sent from my Pixel 2 XL using Tapatalk
I think it is throwing me off cause when you look up the parts it actually has the arm rest as a part you can by but they probably do that so you can buy that individual piece if you need.
My truck does not have the power supply plug just a standard cigarette lighter plug so I am using part number 23467119 this is the synthesis color w/o power supply
DO NOT TRUST THE ONLINE CATALOG!
Always, always, no exception, verify a VIN with the options you want, with whoever you’re ordering from.
Heck, I’d go as far as to recommending people verify the part numbers posted in this thread with the supplier before ordering.  Better safe than, an expensive sorry.
That's what I'm doing now!
On 1/30/2018 at 1:11 PM, scottnaz said:
VIN 3GCUKSEJ9HG145506 can be used to cross reference the console with white stitching, and a satin nickel colored trim.  It’s not the carbon fiber looking silver.
84199890 console assembly
so this 84199890 number is the console that has the white stitching or not?
Anyone selling 2016 Sierra Denali / Silverado Ltz Center console?
Thanks.
Thanks.
I might be getting one within the next day or two. What are you looking to pay?
It's out of a 2017 Silverado LTZ and has the charging lid included.
I’m looking for the cocoa/dune center console. Have a dune jump away for possible trade.
If I have to order Does anyone have a vin # for the brown console with mineral caster trim? No DVD.
I can pay you 550
I paid 553 shipped for a brand new one which includes everything there and the two USB cables you'll need up front
Go to your local dealer and find a truck with that configuration an email gmpartsdirect and say you're looking for the center console for that VIN
Where can they purchase these at? Giving a price with no link doesn't help.
I bought all my stuff from gmpartsnow. I registered then put all the part numbers in left it in my cart for a day and they sent me a coupon for 10% off I paid 513 for all the shit and found the top console piece I needed locally for 40
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
