I put rear headrest monitors in tonight, two Concept CLD-700`s from Amazon.com. Black matches the interior perfectly pretty simple install. Both can play their own DVD but are also linked to share the same disk.
Where do they plugin for power? How are they linked?
Edited by Mad Max
Are the posts too short and move around like the reviews ?
Edited by RKeeper1
2 inch blocks in the back and 3m carbon fiber on the gmc emblem in the grill.
I tapped into the cigarette lighter port in the center console pretty simple. I'm pretty handy so I had a work around for the posts being a little sloppy mine are solid and do not wobble around at all.
Keep in mind as well these do not fit like 100% OEM but they are cheap and easy to install and do the job for me on my truck. If you wanted something more clean or more OEM looking I think you would need to spend a lot more money or get custom head rests made. I "might" be able to remove the DVD players from these head rests and mount them in the OEM head rest but I am not sure and not really sure I would bother.
What I did was slide a piece of shrink tube over the legs of the head rest to give it a more tight fit, they do not wobble shake rattle or move around at all. The worst part is removing the backs of the seats the clips are goofy and delicate I did break one removing it but you cannot tell. The center console is pretty simple to tap into the accessory power port. Inside the lower rear pocket from the back seats there are 4 torx screws simply remove those and pull straight up on the rear part of the console. Then I just cut the plug and soldered the wires to it from the two dvd players.
They are linked via RCA cable because each player comes with 2 inputs and 1 output, so I linked one players out to the others in and vice versa so that each player can share the others DVD OR each player can play their own independently.
I'd like to be as transparent as possible with these, they do sit back a little bit from the actual sitting side of the seats, I don't use head rests so its no big deal to me but as seen in the pictures they sit back about 1" from the seat face. Also one of the units came with a remote that is different from the other and it does not work properly. But the other remote works with both tv's so its fine for me. For the $ I can't see how you can go wrong with these.
I also lucked out I used to have an 08 suburban with RSE I kept the head sets from it, I was able to get both OEM GM head sets to RF link to these monitors giving me free head sets :D
C51F4CE8-BAAA-4486-AD69-969F9D8C8AA8_zps
EC32314A-03C4-4B51-89E1-7B14B1F0707E_zps
Edited by Greensmob
Got my dash cam installed, but I still need figure out how to remove the headliner glass storage console trim and find a circuit to tap off of to get rid of the hanging wire that's now plugged into a power port below. Wouldn't it be nice if one of those many power ports were installed up there to begin with? :banghead:
Which dash cam did you buy?
The G1WH . Could be a knock off but so far so good. Heck- how do you knock off a 1080p dash cam that's only $65 to begin with? - LMAO!
Did you snake your wire all the way around your windshield? I'm thinking splice into something near the rear view mirror. Could power the radar det from there also.
yes,
I ran/tucked the wires along the headliner and the A pillar .Then run it underneath the dash and along the console then plug it inside the console accessories socket..
Got any pics of the grill emblem? I'm on the fence for doing the same to mine. Curious of how it looks
you dont have to remove the headliner to do that. just use your fingers and maybe a plastic screw driver to tuck the wire inside of the headliner and just keep tucking it until you get to an a pillar arm and then you can just pull that off and run your wire.
I did that for my Passport power cord. It was pretty simple and worked great.
I can't post pics if u pm me ur number I can text u a pic
Removed the front air dam, will see if I notice a difference in MPG. Like the way it looks now and I know it will be better after some lift and tires.
I removed the bed emblem for a cleaner look....
What lift/leveling kit is that?
I read somewhere that lifting a truck throws off the speedometer. Would putting a bigger tire on an OEM 20" rim with no lift do the same?
    • Yes they are a good addition to make the truck more visible.   I have the OE ones in the lower front corners. I added some amber fogs to the bumper from Diode Dynamics SS6 model and wired them to my upfitter switches.
    • I had an issue with a new 1985 Z-28 some years ago. The 4WDB's were less than adequate when purchased IMO.  I had taken it in for small warranty services and asked them on three occasions to check them. Each time is was "could not duplicate on the service ticket. The warranty ran out about a month after my last visit and had to take it back for warranty rework. I again complained about the brakes. Well, low and behold, this time they determined the rear calipers were sticking and gave me a quote to repair. They had records as well as O had receipts of each time complained about the brakes while still under warranty. My dad was a life long body shop owner and told me to keep my cool and tell them that I wanted to speak to the GM Regional District Manager. The service manager disappeared for a few minutes, came back and told me they would replace the calipers free of charge.
    • Towing a 2022 Lance 24 ft travel trailer with our 2021 GMC Sierra 2500HD, gas.  Loaded, trailer is about 6,000 lb.  We get up to 10 mpg at 55 mpg, such as I-5.  Pleased with the combination.
    • I decided to give it a shot and see what sort of a gong show it would be to a pan drop themed oil change on my 2025 gas truck with the 10 speed. All indications I had seen so far was that there was no way that pan was coming out of there due to the cross over exhaust pipe not allowing enough clearance for the back end of the pan to duck out from under the valve body since it hangs lower than the pan to trans mount flange and certainly the filter does. I never touched any of the exhaust mount hardware at all, be that the engine manifolds to Y pipe, the bracket on the side of the transmission, or the two bolt flange further back behind the trans/transfer case. I put the truck up on four jack stands as there was no way I was going to struggle with that lack of clearance under the truck. The truck was cold as it had sat over night so all the trans fluid had drained to the pan, so I drained the bit of oil that would come out of the level check plug at the bottom near the front of the pan and put the plug back in to reduce the ensuing mess after that. Then took out all but one bolt front and rear and then pushed up on the pan and took out the remaining two bolts and then let the front of the pan tilt and spill out most of its contents into a drain pan. I then popped the pan gasket off its two locating nubs and kicked it a bit to the left side so it was no longer on the flange of the pan to get all the clearance I could and managed to get the pan slipped out of there by swinging the front of the pan to the right but keeping the rear part of the pan inline if not slightly to the left of its mounting flange area and lifting the front of the pan enough to keep the rear part of the pan low enough that allowed the pan to "JUST" slip out without forcing anything. I installed a new trans filter and seal and as per GM instructions on this site I torqued the two bolts to that 44 inch pound goal ( they take an 8 mm socket ) In reversing the pan procedure after I had cleaned up the pan both inside and out completely ( touching the outside of a dirty pan and dealing with installing a gasket at the same time would be a disaster ). First I slipped the pan into place and yes it took me a while as it won't go unless its slid in just at the right angles, then once the back of the pan was into the area of the flange mount, I went and got the gasket and then threaded that through the front of the pan and feeding it under the filter etc and finally working it onto the flange of the pan and lining up the two locating nubs to drop into the pan. Then lifted the pan up into place and get a couple of bolts started and check and make sure the gasket is where its supposed to be as the bolts were being put in. I never used any power tools as I don't have any of the whimsy little drive guns, I use what looks like a small screw driver handle with shank that has a 1/4 drive on the end of it and added an extension and those bolts use a 10 mm socket as some times power tools can bite a person if used on delicate parts ( torqued to 80 inch pounds ). Also should note as per rules around pulling the add plug out first, yes I cracked that loose with a 8 mm Allen bit socket on a 3/8 slim head ratchet as there isn't a lot of room to work with there either due to the exhaust on the right side of the trans.    I already had delco ULV oil on hand and of course the quart bottle pump wasn't made for those small cap threads so I had to use some other containers that the pump would fit and keep transferring oil over into them so a wasted exercise there but indeed the small pump did work just fine as ULV oil is thin and easy to pump in summer time weather. I put in 9.5 quarts as per prior minimum recommendation and yes that cut it pretty close as once I had the truck ( off the jack stands so its level ) and the trans oil up to 167f , about 6 ounces came out but a level kit or what have you could throw it off just enough that it wouldn't be enough oil so probably that 10 quarts is a good amount to put in so one doesn't have to add more oil as when its hot I sure wouldn't want to be adding oil so would have to let the exhaust cool. All I do for warming up the transmission is sit there with it in park and rev it to about 2500 rpm and it takes close to 20 minutes to get it up to that lower limit of 167f, weird how it will warm up more doing that then by driving it, I am not real keen on power braking the truck to get the temp up there and don't seem to have to either. By the way I only have 9000 miles on the truck so probably not a very good payback on doing it that soon and the magnets had such a minor thin layer of fines on them so that was good to see and the color of the oil was a darker red then new oil but still looked very good as it should and I've not done any towing with it so its been living a pretty easy life so far. The filter is made in such a way that its next to impossible to pull out the filter media but there certainly was some fines showing up there which makes sense give the trans having to break in.    I hadn't really planned on explaining this much of what I had done since there are various instruction videos kicking around or I think so, as the gist of my message as that by fluke or what have you, for some reason my truck has just enough clearance to slip the pan out from the trans. Of course there is no guarantee that other trucks like this in general will also allow the pan to be taken out without messing with the exhaust as I expect its probably a crap shoot if it will or won't, I was just happy to find out that mine would work and avoid all the other struggling and possibly damaging things in the process,
    • Do you fellas think Fog Lamps would  be a good upgrade for our 2024 2500 HD Custom ? As you probably know it did not come with them ,  Would you put in GM Chevy parts ? Do they get wired up to the switch panel ( Upfitter or whatever the correct terminology is ) on the dash ? Thanks
