where did you get the Z71 badge and how does it stay on that? Looks awesome!
How did you do that red stitching? Looks sweet.
He took a red magic marker and traced the thread with it. I believe it was a cloth marker. Do a small line and then wipe off the excess as you go. It really only works on leather though as it can be wiped off easier and not soak in where you don't want it to.
graves- I'm liking your wheels.
This happened on mine today. Nothing out of this world. They're the $200 eBay 5" nerf bar special lol they're sturdy and will definitely get the job done.
Edited by DarkChariot
Installed the long awaited power folding tow mirrors today.Thank you GM!
Before you attempt something like that, you better check your state laws in the vehicle code on tinting limitations.
Tinting the windshield in most, if not all states is illegal and may cause you to NOT be able to pass state inspection. I believe the tinting allowed on the front windshield is usually not to go below 4" from the top of the windshield. There is usually a little tinting from the factory at the top of the windshield. Where that ends, that is usually the limit.
When I was in high school, I had my front windshield tinted in my offroad vehicle and it sucked. Visibility was terrible, even with the sun blazing in the middle of the day. IMO, it would be extremely dangerous driving at night with the windshield tinted. It's not worth affecting your visibility and possibly hurting or killing someone out on the road because you can't see properly out of the front windshield. If you want to know what it's like at night time having the windshield tinted, try driving with sunglasses on. That will give you a pretty good idea of how difficult it would be to see after tinting.
Not legal here, but mine is done and also has the strips. I got the Lumar Air Blue and love it. You can't even tell its there. It just blocks the UV and reduces heat. If they bust you for it they have scratch at it ti fine it and are alrady in trouble. Can see perfect at night and don't even see it with polarized glasses on.
http://www.aptinting.com/llumar-air-blue-80/
Forgive my ignorance, I'm new. Can you share the details? Where you purchased? Where you installed? Review? Thanks.
http://www.gm-trucks.com/forums/topic/164349-201415-hd-powerfold-oem-tow-mirrors-the-ones-weve-been-waiting-for/
Take a look at this thread for more information, Supercharged SS is the vendor that was able to get these mirrors. If you have power folding mirrors now then these are plug and play. The power folding, turn signal, power mirror, programmable mirror, etc. will all work. They have amber clearance lights and white LED's which are new to GM and these lights have to be wired to work at this time. There are folks looking into programming the truck to have them work as well. At this time GM has not offered a reflash to make these lights work on 14's. The mirrors are an option on 2015's. I did the install myself and can provide more info or pics if you decide to do it.
Bath time today. Friday was retractable boards, paint the headlight trim, and repaint the chipped bumper.
Edited by seansharley
Wow! So no problems with auto-dim or tilt on reserve functions? ... I think I might be sold should your answer be a positive one.
Are you taking orders? I think I found your eBay page and it says the passenger side is on BO?
Thanks again bro
Cleared the corners and installed switchbacks along with Putco bulbs in low and high beam.
Clear Corners With LED Switchback (White)
Clear Corners
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
    • The TCM has to be flashed before it can drive.   If you installed it the way it is, it has the OS (operating system/program) from the 2010 truck you got it from. That will not match with the VIN/OS pair that your 2013 truck has.   You can do the full install. Then tow it to a dealership and they can flash the trucks PCM/TCM with the latest program for your VIN.
