No it's the incline of the driveway, truck is level. I will post better pictures when I can figure out what I did to add pictures. Lol
Thanks Crf450r420! That helps! By chance did you mess with the trim around the far left and right AC vents. Im in the same boat with those. I can get trim tool in there but get too nervous its going to break before anything releases.
Pull off the side fuse cover first and the ac vents will pull straight out.
How do you get the side fuse cover off? Do you just pull?
Yep! Just pull. Just try not to break the tabs
Installed a set of replica black chrome sierra wheels (20x9) along with 275/60r20 Toyo ATIIs. Also, finally removed the front air dam and installed an Airaid CAI.
Where did you get those wheels? or are they through GM? They're awesome
I had those on my '13 Silverado. Bought them on Ebay. Available in Chrome, black or black with machined face.
http://www.ebay.com/itm/20-GMC-Chevy-Wheels-1500-Sierra-Suburban-Replica-Rims-2014-sty-Chrome-Set-of-4-/161382854182?pt=Motors_Car_Truck_Wheel_Packages&hash=item25932aee26&vxp=mtr
They're now making them in 22's also!
Edited by Luster
Could days ago but finished putting my led lightbars in behind the grille. Have a 20" in the middle with two 7" ones on either side pointed slightly outward. Couldn't be happier with the result. Started with he 20" on the bottom but moved it all to the upper half of the grille. a5anura7.jpg
I'll get day pictures of the front tomorrow.
Low beams only
Lows with LEDs
Sent from my SM-N900T using Tapatalk
Added a 30" light bar vleds headlights and fog lights. Also Plasti-dipped the chrome honey comb. I have to redo the grill I was in a hurry and when I removed the tape it peeled a little off. cd76d99c0be47972af7a9a615dcc4927.jpg614cd90ace47c2a58aa38f9d65f2aaf0.jpg649e8beb34b906cfae4ea3553c1b413e.jpg3f9df08c8e3f880c1d0415e23f9496bb.jpg8a8700908ff68c8653431483f253089e.jpg
Im diggin that plasti dipped grill.
    • I have never seen GM instructions for the other trucks as per the HD with the 6 speed or the half tons but had got the impression that the HD trucks with the 6 speed were not having the same problem that the 10 speed and pan presented. Also video that I have seen of the HD 10 speed with the gas engine starting in 2024 model year showed that it was a real struggle to even make it work when pulling down hard on the exhaust after undoing the exhaust hanger bracket on the side of the transmission as after all there is little room for the pipe to even go down behind the Y joint as it soon would hit a frame cross member. Also that they had tried just like I did with the gasket off and no way was that pan coming out any way they tried to manipulate the pan. From that as well as the local transmission shop talking about the pain in the rear issue, I was not expecting my pan to come out because GM shows it was not even intended to come out without dealing with the exhaust piping.    It would be nice to claim, here's what you do and its easy to remove the pan guaranteed on any HD truck with the gas 10 speed but dollars to donuts the next guy trying what I did would not have the same luck as the exhaust was just manufactured slightly different and be pissed off at my claim that the pan comes out with no issue. Its more of a try and see if your particular truck might work like mine did .... or not !.
    • Sorry I didn't see this until now, but it works on both the 6 speed and 10 speeds, as well as all the half tons too.
    • Hello, I have a 2018 GMC Sierra 1500 that I recently changed both motor mounts on due to the driver's side being blown out. After replacement I seem to have a steady vibration that I can feel in the pedals and the back of the seat. At this point I'm convinced that the aftermarket "Anchor" branded mounts I used are not performing as well as OE, the only real reason I ended up using the mounts in question was because my local dealers were out a few months to get a Driver's side mount. I've tried "Neutralizing" the mounts according to the motor mount TSB published for these truck to no avail. My trans mount is also in great shape and seems to be absorbing vibrations swimmingly. As far as I can tell there is no issues idling, my idle RPM is steady and I've recently put GM plugs and wires on, however, I have not cleaned the throttle body or intake valves. Any one else have a similar experience with aftermarket mounts? Patience certainly is a virtue that I wish I exercised here. Thank you!
    • I still saw people out for runs, on their bikes/motorcylces, jeeps with the doors off driving around here the past 2 days. I guess we are just used to it here haha.   Tasted like a bonfire the last 2 days.
    • The TCM has to be flashed before it can drive.   If you installed it the way it is, it has the OS (operating system/program) from the 2010 truck you got it from. That will not match with the VIN/OS pair that your 2013 truck has.   You can do the full install. Then tow it to a dealership and they can flash the trucks PCM/TCM with the latest program for your VIN.
