Try turning the LED bulbs over and plugging them in again. They don't work if they're plugged in "wrong". Ask me how I know :rolleyes:.
Haha i put my reverse lights in and they didnt work. I was heated and about to go write nasty feedback on ebay and send them for a refund. i did one side and 1 light at a time so after it dodnt work i took them out, but somethin said try one more time maybe i didnt have it pushed in far enough.
They worked, then i found a tab on the box that had the sticky label that read "open for important instructions" where it said to flip it if it doesnt work
Oops lol
Oops lol
That's funny. I've done that before not realizing some have reverse polarity and all it takes it turning them around.
Sent from my iPhone 6+
The debate I'm having with myself now is: New Wheels/Tires or Tonneau/Bed Liner
Wheels/Tires will prob be about 1500 more in the end, but I know have until November to get a tonneau (before it starts snowing enough that it wont melt)
Installed the driver assist handle. $53 from my dealer. 5 minutes to install myself. I'm happy!
PlastiDipped the tail lights and third break light. I like the look, just not sure it's as dark as I wanted it to be. I'll leave it on for a few days and redo it with 2 light coats of black vs. only one.
Edited by OSMEAC
Mount that thing to the hood so it shines light down and is more useful[emoji106] Edited by Mike1220
Ehh. Personally not a fan. If I were you I'd just bring them to a shop and have them smoke them properly with a black paint/clear coat mixture so that they are properly smoked and still easily visible. Not saying yours are not easily visible but as they are, they just look older and hazy in the pics.
I played with the placement for about 20 min and there was no real good spot on the hood itself. My 2012 fx4 ford had a nice flat angled lip where I mounted one and it was perfect, this works and is extremely clean as I ran the wires in the core support. It's not perfect, but for as much as I'll use it, I'd rather have it clean looking (actually invisible) over 100% functional. It sounds weird, but trust me there isn't a great spot to mount it on the hood.
Must be a big light. I put 2 small xkglow pods on my hood and they are nearly invisible and functional. Looked into bigger lights but some didn't fit and others looked goofy haha. But either way, it still looks good man[emoji106] wasn't sure if you tried the hood and wanted to make sure
I agree. I think that's why I'm not crazy about them. Perhaps I'll add a few heavy coats of glossifier and see how I feel after. In either case, I might be peeling this off lol
If peel if off tomorrow and drop them off at a body shop
Old pic but here's mine
B48E4D42-4D31-482C-BEB8-40530D379142_zps
http://www.lemonbest.com/2pcs-17cm-led-cob-car-drl-daytime-running-light-fog-driving-lamp-waterproof-12v
Yes it's so simple to put it in.
I just had all of the extra's I wanted included in the deal and I would install them so when I picked the truck up it had the Handle, molded mud guards, and center console tray all in boxes in the back seat,
Took less than an hour to install it all my self.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
