what did you do with the other one? I can't stand my all chrome grille and really want the black inserts.
I still have it. Odds are that I'm going to put billet in it though
if you're willing id pay the shipping to swap you if you're simply going to cut out the insert anyway. I can take very detailed pictures/video for proof of condition if you'd like. Lmk if this is something you may be interested in.
If you have done something to your 14 and would like to share,please post here. Please don't post the How to in this thread.
Have a little time to install the tail gate light bar, replaced the bed light bulbs with led and install footwell led light..
Bed light replaced with this: http://www.ebay.com/itm/111217352865?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649#ht_1381wt_1181
They are super bright..
Tailgate led bar with reverse: http://www.ebay.com/itm/400624564281?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649#ht_2571wt_1155
Not too bad for the price.
footwell led,1 led per area : http://www.oznium.com/prewired-superflux
driverside:
Passenger:
Rear :
Enjoy!
How did you install these in the cab?
Sent from my Nexus 6P using Tapatalk
I did the same thing and wired those exact lights into the dome light circuit, small hole drilled into plastic under the dash on each side and done.
This was yesterday but figured I'd post it here as well
Cleaned her and took her bowfishing
Had to get the sticker in there lol
Never seen a bowfishing setup with a pistol mount before. Must taking on some monster trout!
Lol, had to do it for the pic. We usually go after carp and snakehead around here in the creeks
It's been a busy week for the ole truck. I think I'm gonna stick with project death magnetic for this one.
First of all got rid of these.
Cooper Zeon LTZ. I read great reviews but I could not get these tires to balance at 65mph it felt like the truck was gonna come apart...so i traded them back in and upgraded to Toyo at2
Debadged rear somewhat
Also got some goodies installed with a tune :) Air rade tube with texas speed longtube headers.
Finally fixing the hail damage from when I bought the truck almost two years ago. Taught my helper how to sand so I'm just drinking America's supervising.
Needed a better tire then what i had. (Dick cepek fun country's) So I went with a slightly smaller cooper discoverer. b4f5eeced0c7a64425a8921cd7ca6cd8.jpgd0d4fe0d2678f22b70e2f3a1d8ff5f00.jpg
Not going to lie but that looks horrible. Tires look way too small for your lift.
They are a little small. But oh well. Rides 10x better then it did.
I'm on a Tapatalk so excuse me if this information is in your sig. But what tires did you come from? I know some people don't like the stiffness of larger tires with 10ply.
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
