Got it buffer and sealed spacers katkinz new grill headlights numerous other stuff rc2.5 level new terra graps
Sent from my SAMSUNG-SM-G925A using Tapatalk
looks good - running broads (make /model) ??
Got my muffler swap done. Magnaflow part 12909 swapped and left the flapper and rear resonator on for now as i have 2 small kids. Not sure how long i will leave it this way. Still is really quiet, Especially under normal driving. Wakes up a little under hard acceleration but not as loud as i would like it. I may clamp the valve open and see how it sounds to get an idea of what i may need to do to liven it up a little more. Still waiting on my airraid mit to arrive.
Edited by mjdxtreme
without the resonator, 3 inch pipe out the back and a 4inch tip there is no drone in cab and it sounds great! You'll have a little whistle almost like a turbo! As long as you don't add the Cold Air Intake like i did it'll stay pretty darn moderate/quiet! With just enough growl to make you happy and enjoy the accelerator:)
I clamped the flapper valve open and its amazing the difference in tone. A lot deeper and a little louder rumble just on start up. I have not had a chance to drive it yet to hear what it sounds like with afm engaged and with various throttle applied. So ill report back a little later after i have driven it for a little bit.
UPDATE!!
I have taken the truck on about a 20 minute drive with the flapped clamped open. A mix of city and highway. Much more agressive tone that I am looking for. Not really any drone when afm does kick in but the afm does not seem to kick in as much. I think I am going to leave the flapper in and just leave it clamped open and if i get tired of the tone i can remove the clamp and quiet it back down. I can have the best of both worlds this way if need be.
Edited by mjdxtreme
Got my 'Seatbelt Recall' 2015822B Performed. After much bitching back and forth with GM we basically settled on them replacing the whole side of the seat.
This is what the part looks like if you order it from the factory right now. It is better than the hackjobs .... somewhat and at least is a clean machined 'cut'. Still not 100% satisfied but at least I can say it was not sliced up. I know the service manager did his best in forcing GM to replace the entire piece at their cost so I am grateful for that, at least we stuck it to GM and made them cough up and spend hours of manager & regional manager level labor rates because they cheaped out trying to save a buck.
"Lo barato sale caro." The cheap comes out expensive
20160922 125535
20160922 125543
20160922 141910
Edited by Alpine Truck Life
I'm doing the same thing when I bring my truck in for the airbag recall. I didn't realize they were hacking up the interior pieces of trucks for the seatbelt. Then I came on here and saw the posts. Sure enough mine looked like all hell.
Arn't you the fellow who had the hail damaged truck too with fiberglass hood? Your poor truck has been through the ringer, and then to be sliced up it just a sick joke or twist of irony.
Hope they can clean it up for you! Its looking much better now!
I am but I bought my truck for half off because of the hail. Don't feel too bad for me. She's almost ready for Line-X. Probably next week!
You going to line-x the whole thing? I love the look of that hood btw.
Yes, Line-X premium so it'll have a gloss finish. Then the grille inserts and a couple other odds and ends will be painted a gun metal gray.
    • Long Term Cold Cycle Limited Testing   Back to the 1990's and XOM's million mile test. Since then there have been others and there will be more. Schaeffer's, AMSOIL to name two. Of these Schaeffer's is the stand alone which I will explain in a bit later.    http://papers.sae.org/600190/:   http://papers.sae.org/850215/:   Up to 75% of  engine wear occurs on cold starts. These two links (above) provide the technical reasons for engine wear. In a nut shell, and by a large margin, cylinder wear is what takes out most motors and even with a pre-oiling system that part of the engine is dry enough on cold starts and cold warm up to pierce Stribeck.   So when you put a motor, or a car, on a dyno for a million miles stopping only for oil changes, (yes fuel is uninterrupted) or break down maintenance, you are depriving the test of the most important part of it's wear cycle. Yes a million is then a pretty easy walk even for a mineral oil under those conditions.    How about cleanliness during the long test cycles? Same thing. Varnishes that stick rings and insulate parts are laid down by repetitive 'heat cycles'. It's the cool down the precipitates the varnishes. These long runs also hinder acidic attack caused by cold start richness and less than optimal cold start ring sealing. They hinder water formation and enhance breathing of the crankcase; the petri dish of acid formation, the first step in sludge formation, amalgamation and precipitation. These motors are also monitored and controlled for water and oil temperatures to within the "normal operating range".      https://www.swri.org/sites/default/files/sequence-iiih-test.pdf Note the test sequence in some boutique oils literature for testing, API IIIH, is not the standard used for the ILSAC G7 testing. Does that mean it is irrelevant? No, not as used. As used as a 'visual guide' it makes it's point. The G7 weighted piston deposit minimum is lower.      Back to Schaeffer's. That was a cyclical test of an engine in fleet service and not a dyno mule and if you saw the video it was not mirror clean but wear was low.    There are oils like BioSyn and other 'Renewable" source oils that taught cleanliness and have proven themselves in fleet testing. Havoline an other example.    The newest ILSAC G-7 test prioritize cleanliness, LSPI mitigation and fuel economy OVER WEAR. In comparison Porsche C30 Specification Verses ILSAC G-7 Specification below:      Some will balk that this graph isn't apples to apples and I will challenge that in that this graph represent the SPECIFICATION and not the any One Oil Performance.   It is absolutely possible to minimize wear, maximize cleanliness and mitigate LSPI etc., It just isn't cheap and currently I see none that are not walking toward profit over performance.
    • It has happened to me a few times. I carry a jumpstart-tire inflator with me.
