2 hours ago, pgamboa said:
Not in the glass. This is how they were wired up out of the box. Since my door handles are white running lights, I didn’t want to have amber running lights on the mirrors, so I made them all behave as a turn signal and flash amber like the handles and front headlight. Keeping the same lighting profile.
What type of truck magic is this!? You are so  clever with the wires and the electrical thingies!
Man. And here I was all happy to post that I put LED backup bulbs in and LED license plate bulbs. Then ya got this guy with illuminated door handles and fancy mirrors.
  • Like 6
Installed diablo stock tune today. Wow!
Do elaborate. What’s your truck set up? 6 or 8 speed? Tell me the pros and cons. I’ve been tossing around this idea for a while. The more I drive my truck, the more things I nitpick about the way it drives. Throttle lag, weird shifts in V4 mode with the 8 speed, etc.
4 hours ago, pgamboa said:
- Testing out these aftermarket DL3 Mirrors. They support power fold and memory (just like the factory DL3s)
More about these mirrors please. Are they offered in colors other than black ?
I have a set of factory DL3 mirrors to put on my 2018 Silverado LT but these look interesting.
These mirrors would be perfect if they had switch backs!
Sent from my SM-G955U using Tapatalk
Yes! I’ve already opened discussions about switchbacks [emoji6]
Post it up! I’ve gotten many ideas from this thread! [emoji51].
Just gloss black but can be color matched.
1AMRP01660 is the part # from 1A Auto.
Been a while since posting here since I barely get any time to myself these days [emoji4]
- Picked up an embossed grille and stole the upper trim off of it. Retrofitted it into my grille.
- Got my headlights back on. Got the corners cleared with Klearz (courtesy of Crisp GM Customs).
- Handles are now switchbacks (courtesy of Crisp GM Customs)
- Truck got a bath (LOL) - so neglected.
UPR Catch Can, Borla Catback Exhaust, and new NavTV - GM650, and Redline Emblems are next on the list to be installed - IF I can get a free day.
Are you mirror puddle lamps not white led? And what mirrors are those? Caddy?
Hah. True. For the reverse lights I got a set from American Trucks. Axial brand 210 lumen. They’re pricey, but I didn’t want to mess with resistors and such. They have a 410 lumen kit, but $90 is really steep for backup lights.
https://www.americantrucks.com/axial-210-lumen-backup-light-led-conversion-kit-921-14117.html
For the license plate lights, I had some of these left over from converting some bulbs over in my Malibu. These do need to be inserted the right way or they don’t work. But, they look more “modern” than the yellowish incandescent bulbs.
Yorkim 194 LED Bulbs Xenon White 6000k Super Bright Newest 5th Generation, T10 LED Bulbs, 168 LED Bulb, LED Bulbs for Car Interior Dome Map Door Courtesy License Plate Lights W5W 2825, Pack of 10 https://www.amazon.com/dp/B00JRE38EA/ref=cm_sw_r_cp_api_i_cWQzCb3AP594S
Here’s a bad photo in the single digit morning temps to kind of showcase them.
  • Like 3
I’ve also learned a lot from this thread too. For example, you mentioned not wanting to worry about resistors. I learned that resistors are only needed for the turn signal circuit if you replace incandescent for LED (for to the current draw). I guess there is some FMVSS (Federal Motor Vehicle Safety Standard) regulation that requires the turn signal to have some method of detecting a bulb “outage”... so this is achieved by programming the BCM to look for the correct current draw. For any other lights... you can swap to LED all day long. Turn signals... require resistors. :)
There is always something new that I learn from this thread... so I encourage any mod, large or small, to be posted for that reason :)
They are white LED (shines downward). SUV platform mirrors won’t fit. These are specific to K2 Trucks. They are from 1A Auto, but I got them directly from the Manufacture in Taiwan.
I’ve also learned a lot from this thread too. For example, you mentioned not wanting to worry about resistors. I learned that resistors are only needed for the turn signal circuit if you replace incandescent for LED (for to the current draw). I guess there is some FMVSS (Federal Motor Vehicle Safety Standard) regulation that requires the turn signal to have some method of detecting a bulb “outage”... so this is achieved by programming the BCM to look for the correct current draw. For any other lights... you can swap to LED all day long. Turn signals... require resistors. [emoji4]
There is always something new that I learn from this thread... so I encourage any mod, large or small, to be posted for that reason [emoji4]
I’ve read stories about LED reverse lamps staying lit, so I wasn’t sure.
I have a 5.3L 6 speed Silverado.  I installed the Diablosport preset 87 Octane ECM Tune and the Firm Shift TCM tune.  The truck has more consistent pep now with smoother, firmer shifts.  A couple months ago I was considering trading up to an 8 speed thinking more shifts might be smoother.  Am glad I did this instead.  Can hardly wait to get my DiabLew custom tune done in a few weeks.
Bear in mind that unless something changed recently I don't think the 8 speed transmission can be tuned yet...
17 hours ago, pgamboa said:
Been a while since posting here since I barely get any time to myself these days :)
There just isn't any other way to say this...Phil you have one bada$$ truck right there!
    • I just brought home a 2020 GMC 1500 Denali.  She has 53K miles on her and I want to change out the fluids over the next few weeks.  I see the diff covers don't have drain plugs.  Any suggestions where I can pick up front and rear diff covers with drain plugs?   Thanks,   Bob
    • Well, the dealership got the compressor and installed it. Air at the vents seems nice and cold as it should be. The service manager said the repair has a two year warranty and unlimited mileage. Hopefully I don't have to use it. The dealership i went to was one where I bought my 2014 half ton silverado. In 10 years and 168k miles on the truck anything I needed done and two small recalls they were always very good to me. Not a huge dealer either. I think they treat people well because they want you to come back. I have dealt with a different dealer that was too big to care about an individual. Just my two cents.
    • Hi All, I operate my 2021 3500 SLT most of the time with the tailgate off and in a crate because I have a slide-in camper. However, at least once a year, I take the camper off and put the tailgate back on. Recently I installed the tailgate, but had a hard time getting the connector bail to swing to the fully latched position. The connector seems to fully seat, and everything works, but the bail doesn’t swing to fully latched position.  It swings almost there but stops and I am afraid to push it any harder.    Does anyone have any advice on cleaning or lubrication or anything else I should be doing?  i know how to properly operate the connector. During the time the tailgate and connector are off, i have a double plastic bag over the truck connector secured with rubber bands to keep it clean, but it still had some dust in it this time when I blew it out with compressed air. I didn’t want to spray it with anything other than air without doing some research. Thanks.
    • There are a lot of spammer's that do that, quote something and add some commentary to make it seem legit, but modify the quoted text a bunch making sure when posted it's long enough to be "click to expand", and either immediately insert a spam link, or come back after some time and edit it to add the spam link.
    • Hello @jaszr2 Do you have a link for the item? I put a replacement bumper on my truck and consequently had to relocate the shutters. I studied on them a while, and figured if you left a couple key blades, you could get most of the airflow with probably no throwing codes.
