14 hours ago, 300 Blackout said:
Picking up my brand new, illusion cherry powder-coated 2014 Sierra frame from Quality Powdercoat and Sandblasting in Highland, Michigan. These guys did an absolutely stunning job with the frame and it wasn’t easy. The frame wax was a nightmare to get off. It had to be sand blasted, baked in the oven to melt, spot heat applied in the areas the wax was hiding, then sandblasted again. They then applied the base cherry color, baked it and had to apply the clear coat after the cherry glazed over in the oven but before it cured per the application spec. They then baked it all together to cure, let it sit overnight, and baked it again. Mad props to Brian and Jake at QPC, their attention to detail was impeccable and the result is nothing short of stunning.
YES! yes! Lest see the suspension! What color body?
I bought a G2 Bakflip a while back but decided to sell it for something I could shut the tailgate without having to open the cover. But I couldn’t sell it, so I just threw it on my truck.
3 minutes ago, H-town Silver Bullet said:
I apologize for my ignorance, but what is that?
Alpine 455u amp.
22 minutes ago, 300 Blackout said:
Little by little I’ll powder additional parts. Right now the suspension is black. 124bdb293f0f5ff5d84b6562ee0168de.jpg
Great looking truck. Are those 35s?
installed fog lights yesterday [emoji1360]
just need to order the gen5diy harness to wire them in now.....9b0bdf28e363b74361cb2419f2ce00e9.jpg10517dff184c2745f87b4f36c59ffc3d.jpg
What’s the setup? Sharp truck
Thanks! I’m gonna start a build thread soon. It’s been a work in progress but I’m really happy with how it’s turned out. Here’s a list of specs:
- 2014 GMC Sierra 1500 All Terrain 5.3L 4x4
- 4.56 Gears (Yukon Rear, Motive Front)
- Shaftmasters Aluminum Driveshaft 0.125” thick, 5” diameter, ~71” long.
- Spicer 1415 u-joints
- PML rear differential cover
- Amsoil Severe Gear 75W-90
- Cooper STT Pro 275/65R20 tires (34” diameter when new)
- Bilstein 5100 Ride Height Adjustable shocks on second highest setting.
- Engine Vacuum Pump Delete
- CVR VP655 Electronic Vacuum Pump
- Amsoil EaBP90 Engine Oil Bypass Filter
- Speed Engineering Long Tube Headers
- Speed Engineering True Dual 3” Stainless Exhaust with X-Pipe, axle dump
- All cats deleted
- Dual Borla Pro-XS mufflers
- Morimoto Mini D2S 4.0 HID Projectors
- Morimoto D2S 4500k HID Bulbs
- Morimoto XB LED Fog Lights
- 1000 lumen LED Reverse lights
- 5% 3M tint in all windows except windshield
Pending mods:
- Installation of new powder coated frame
- Passenger side lightning exit for dual exhaust
- Dual high flow cats after x-pipe
- External transmission fluid filter
- Dual vacuum reserve tanks for brake booster
- SLP TVS1900
- Triple gauge pod A-pillar for wideband air/fuel ratio, oil temp, trans temp and/or boost gauge.
Possible Mods:
- Crankcase exhaust evacuated directly to header collectors from valve covers.
- PCV valve delete, replaced with breather
- Engine Oil Accumulator
Put a new bumper on my 16 & added a color matched tailgate handle.  Go rear ended last week.  Lucky they had insurance and paid up quick so I could get new bumper and get it painted and installed this weekend.
  • Like 5
I gotta say that bumper looks real good. I may need to get myself one.
Sent from my SM-G955U using Tapatalk
Seems kinda worthless if you have to leave your phone in the truck. Or did I miss something?
Does the phone have to be in the truck or do you just need to be in Bluetooth range? Would be handy if you can unlock with your phone if you manage to lock the keys in the truck.
Sent from my Moto Z2 Play using Tapatalk
L150,
Where did you get the bumper?..... I got rear ended recently and was looking for an option or two other than stock before taking it in. Looks nice and clean. Thanks.
Sent from my SM-N950U using Tapatalk
    ChristopherDobson
    ChristopherDobson
  • Who's Online   3 Members, 0 Anonymous, 1,252 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
