Got my headlights from Strykers_Inc today. Can't wait till my trucks out of the body shop next week to install them. Also got some covers for the pods on my hood.
ADACF23A-83D5-476D-9B61-B597AB4C80BA_zps
AEC7CBC6-7344-4BC5-AE6D-6DE42C032171_zps
headlight photo's when install. are those your landing lights ????
Also got my front windows tinted.
  • Like 4
Not today but got my aeroskin hood shield put on...love it!
Sent from my SM-G930V using Tapatalk
Picture please 15Blue
Agreed .. pics please
CDDC2272-28B3-4088-BA06-226D88C76A73_zps
5998CDF5-05EE-47FE-9DA9-404ED06FBC6A_zps
Pics of the aeroskin on a black truck. I love it. Can't even tell it's there unless you know what you're looking for.
  • Like 11
good looking truck. you have to much free time ( Headlights / fogs) ? how hard was the headlight ?
Thanks. Headlights weren't that bad. Permaseal is a PITA to open. Cut out amber reflector and put in Klearz. I bought a spare set of lights to work on so I could take my time. You can get it all done in a day though. Clearing them and painting the trim.
That is a nice looking truck indeed. I have no idea what I'm looking for or know what Aeroskin is. LOL. Guess I have to google that one. [emoji51]
Ok googled it. I see it now, but barely.
Edited by pgamboa
Exactly. I wanted something that had protection, but didn't stick out like a sore thumb. It was my Father's Day gift last year.
If you look close you can see the avs emblem on the drivers side of the aeroskin just above the grille.
Yeah you can hardly see it. Looks super clean, I normally don't like those things at all, but that looks good
Got a link to the one u have. I have black truck and have considered this with all the sand we use for winter road crap gets flung up everywhere
One question, Can you see the tape beneath the shield once it's installed?
Thanks,
Bob
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
