Changed the transfer case fluid and greased the two zirks on the tie rod ends. Surprised at how dirty the fluid was at only 27k, fells good to have new ATF in there, also Severe gear in both front and back pumpkins.
Edited by Bobaloo22
how hard was the frameless mirror mod? thinking of doing this myself
If you already have an auto dimming mirror, it is relatively easy with a Gen5DIY harness. Their harness moves the power pin from on slot to another. It also provides a GMLAN tap circuit from the back of the radio.
If you don't have an auto dimming mirror, it'll be more involved as you'll need to get Power ran to the mirror. At that point, you might as well run the auto dim circuits so that your DL3 Driver side will auto dim as well.
Not too bad, used the adapter harness from Gen5diy. I also had to add a 12V supply to pin 10. I think this was because my original mirror was not auto dimming.
Were the steel bushings on your 2.0's centered? Mine were not and I couldn't move them so I installed them as was. Just curious. I installed my 2.0 coil-overs this morning before the superbowl and will say you may need a extra person to help slide the bottom of the coil-over on top of the lower control arm. I also changed my sway bar end links with moog since I had to remove them.
Yea, mine were off some. One was real bad and I used a dead blow hammer to get it moved over but still not centered. Thanks for the info on the coil-overs.
I don't know much about Fox, but I have the Bilstein's and my truck rides like a Cadillac compared to the stock ranchos...I have a level so obviously I feel the smaller bumps and what not, but when I hit the bigger bumps the 5100's don't bottom out, night and day difference....
Sent from my XT1254 using Tapatalk
Do you have the shocks set up to level the truck or a different leveling kit? I have the RC 2" and was wondering about what shocks to choose when the time comes.
Swapped out the Bow ties for Billet ones, had the front windows tinted and changed out all the rear white lights out with LED. Installed the Bakfilp from my 14 onto this 17
Now just deciding which Borla to go with GM, touring or the S-type
Newest additions:
• Flowmaster Super 40 muffler swap
• OZ-USA 30" light bar behind the grille
• Desparately needed hand wash
https://youtu.be/Ff2yVYJJhBM
I have a vid of better clips coming in exhaust thread if anyone is interested in the Super 40 swap
Edited by quise2024
Installed my power folding switch. 4 bolts and a few tabs and it pops right out and in. I thought the mirror controls did t work at first because the new switch is lighted. You just have to press the buttons 5-6 times to recognize it and then it'll light up.
When you transition from left and right mirror control, it seems that there is a timer delay before the fold button activates. Drove me crazy at first.
I"ve thought about painting my calipers, but don't know which color would look good with the 20" oem chrome wheels and tungsten metallic? and still trying to decide whether it looks good or not
I have that setup with red painted calipers. See my gallery. In my opinion they aren't very visible with the OEM wheels. I'm considering replicas with a more open pattern. I'd like to get someone to video me driving by so I can see how visible they are in motion.
Sent from my Pixel XL using Tapatalk. My build thread: http://www.gm-trucks.com/forums/topic/192614-tenscourts-2016-ltzz71-ccsb-4wd-silverado/
Installed the Camaro DBX - Frameless Auto Dimming Mirror! Thanks Alexantics!e20d48fc32ad352e3f2d4927f62bc595.jpg4859c33544c96a25ed32cd5a87901d7c.jpge8198bede5d824460a72d914a6f95e8f.jpg
your factory mirror is auto dimming correct? Would you like to sell it?
Well.. my truck is an LT. The factory mirror that came with my truck was non-auto dimming. However, I swapped it for the auto dimming mirror shown in the picture. Still not sure what direction I want to take yet as the frameless mirror is a little smaller than the framed one.
i too have an LT, please write my name down somewhere. If you do get rid of it, please pm me.
Now just deciding which Borla to go with GM, touring or the S-Type
I went with the S-Type and love it, just enough rumble and doesn't sound obnoxious.
Edited by bdkidd01
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
