Washed it the other day.
Sometimes I think about changing the wheel/tire setup and lowering the stance but pics like this change my mind haha! 772495a0d60dc2439cb115fb9846f15e.jpg
Edited by Imperial91
  • Like 7
Looks perfect!
Like lowered trucks might change you mind
Sent from my SM-N920T using Tapatalk
What a bunch of weenies at your local UPS. Lol
Freedommunitions seems to have the best price so far. The switch is priority though. I have all your R&D into the harnesses and love my signals. I need my power folding switch and a diode to complete this project. Now I just need to make it to RadioShack.
Thanks again!!!
I signed up for freedom's mailing list, now I just wait for those email deals and it's on! Best prices I've found as well.
Sent from my kayak
Well damn. That looks nice haha. It looks a little funky with the 33's. if I lower I don't know if I will keep same wheels and go with different tire or switch wheels to maybe some 22's. The current wheels are 20's.
Thats sounds amazing.
What is the model number of this muffler? was it an easy install? (Cut and weld, or were bends required?)
I have the 5.3 and i have had a hard time deciding muffler vs. delete.
Thanks! I dont have the model #, but I can call the shop and get it if you want it, it is a 14". It is a weld, and all I did was the muffler and removal of the resonator. Best $200 I have ever spent!
FYI - that is on a cold start (35 degrees), when the truck warms up it gets quiter. I love it because you can hear it without it being obnoxiously loud.
Edited by White Sierra
Did you remove flapper? Or just muffler replace and resonator..
They told me just muffler and resonator.
If they removed the muffler, I would almost bet that they removed the flapper too since they are so close to one another.
Autocal came in today. Scanned my files and data log, now just waiting on the new tune.
You are gonna' think you have a different truck after your tune. The TCM tune is worth the price alone. Be shure and have your idle RPM raised 100/150 for a little better throttle response. It really help mine plus it sounds better to me.
What wheels are these and where did you get them?
Thanks,
Eddie
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
